Does spare tire have TPMS sensor?
Potter
Raptor and Bronco
I just brought my 23 wildtrack in for its first oil change tire rotation at a local Ford dealer. I asked them to do a 5 tire rotation and the service advisor stated that the spare does not have a tpms sensor and it would throw a light if they rotated it in. Is it true the spare does not come with a tpms sensor from the factory?
Potter
Raptor and Bronco
No, it's not. I've done several five tire rotations with the stock wheels, no problem. They do have to run the reset afterwards so it detects which are mounted.
is there a way for me to manually do the reset?
Fly
MA
Subaru Outback
They just dont want to lift that ~90lb tire onto the rear carrier. Ive done the 5 tire rotation myself without any TPMS reset necessary.
userdude
Denton, TX
2023 2dr Badsquatch
Sure. I believe it's just a matter of pushing buttons to go into find mode (no FDRS or anything).
@Ducati1098, do you know how to do this?
Note, the dealer should do it, as well as any competent tire shop.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I've never reset anything when rotating my tires, the system figures it out pretty quickly...
userdude
Denton, TX
2023 2dr Badsquatch
I saw that above. The shop that's done three or four of mine do a reset, because I've asked. I don't know, maybe it's not necessary or there was some miscommunication.
Edit: Now that I think about it, I did get a flat once and changed to the spare and it took maybe 10-20 miles before it stopped complaining about that tire. So maybe they do the reset so I don't bring it back and complain? They do something.
userdude
Denton, TX
2023 2dr Badsquatch
I sat there and watched the guys doing mine once get up on a rickety ladder and pull the spare off. It would've been funny if it didn't look so dangerous. I asked why they didn't just put the lift down it was on and they kinda had this far off look... lol
HeliPilot
Kenny
CT
2022 2.7L SAS
Thanks everyone. I called the service manager and let him know his guy is an idiot.
No need to perform manual reset. If you throw it on, drive it down the road and within 6-10 minutes the sensor will automatically acquire.
ebrs929
Erin
2022 Bronco, 2009 F150
Same here. First tire change we did in a truck stop parking lot at 11pm one night (ps - welding rods and tires don't mix). We have since done two 5 tire rotations at a shop and at home.
Never reset anything, just kept it moving. Never had an issue or error.
timhood
Tim
Several
I just brought my 23 wildtrack in for its first oil change tire rotation at a local Ford dealer. I asked them to do a 5 tire rotation and the service advisor stated that the spare does not have a TPMS sensor and it would throw a light if they rotated it in. Is it true the spare does not come with a TPMS sensor from the factory?
OMG, that service advisor is uninformed. Not only does the 5th tire have TPMS, but your Bronco will automatically recognize when you rotate it in. Trust me, I've changed my tires at least a dozen times in the past year. Not only will the Bronco recognize the spare rotated in, but it will also recognize the TPMS sensors on a complete second set. I run these as my street tires:
Ford Bronco Does spare tire have TPMS sensor? tempImagercgII
And regularly swap in my OEMs for off-roading. I've never even given the TPMS sensors a second thought. They just work.
Ford Bronco Does spare tire have TPMS sensor? tempImageUJovII
Bellime
Keith
2022 Ford Bronco
One thing I wish the tire pressure display would show is the spare tire
Ducati1098
Here are the instructions for doing it without FDRS. You’ll still need some type of Ford compatible TPMS calibration tool though.
Programming
NOTE:
Enter Training Mode Without Scan Tool
  1. NOTE: The horn will sound once and the TPMSindicator will flash if the training mode has been entered successfully. If equipped, the message center will display TRAIN Left Front (LF) TIRE.
    With the ignition OFF, press and release the brake pedal.
  1. Using the start/stop switch, position the ignition from OFF to RUN 3 times, ending in the RUN position.
  1. Press and release the brake pedal.
  1. Position the ignition to OFF position.
Programming
NOTE:
TPMS Sensor Training Procedure
  1. NOTE: It may take up to 6 seconds to activate a tire pressure sensor. During this time, the special tool must remain in place at the valve stem.
    Within 2 minutes of the horn sounding, place the special tool on the Left Front (LF) tire sidewall at the valve stem. Press and release the test button on the special tool. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the BCM .
    Use Special Service Tool: 204-D081A (204-D081) Tire Pressure Monitor (TPMS).
  1. Within 2 minutes of the horn sounding, place the special tool on the Right Front (RF) tire sidewall at the valve stem and press and release the test button to train the Right Front (RF) tire pressure sensor.
  1. Repeat Step 1 for the Right Rear (RR) within 2 minutes of the horn sounding, place the special tool on the Right Rear (RR) tire sidewall at the valve stem and press and release the test button to train the Right Rear (RR) tire pressure sensor. For Left Rear (LR) tires within 2 minutes of the horn sounding, place the special tool on the Left Rear (LR) tire sidewall at the valve stem and press and release the test button to train the Left Rear (LR) tire pressure sensor. The procedure is completed after the last tire has been trained. When the training procedure is completed, the message center (if equipped) will display TIRE TRAINING COMPLETE. For vehicles not equipped with a message center, successful completion of the training procedure will be verified by positioning the ignition to OFF without the horn sounding. If the horn sounds twice when the ignition is positioned to OFF, the training procedure was not successful.
