- Joined
- Feb 29, 2016
- Threads
- 37
- Messages
- 1,234
- Reaction score
- 6,482
- Location
- Mentone, CA
- Vehicle(s)
- 70, 71 & '21 Broncos
- Your Bronco Model
- Base
Yeah there's no good way around it unfortunately. Using higher grade alloy steel adds cost, as does heat treating it. Best is to just add a proper nut, either loose or welded. But you can get un-plated weld nuts so at least you don't have to grind the plating off before you weld them. And 1/4" would be plenty thick if you're not cutting threads into it.They are mild steel. I didn't think it would be a problem so good catch. My goal is no loose nuts and I was hoping to skip the step of welding nuts to the plate.
