Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Dusty
Mentone, CA
70, 71 & '21 Broncos
They are mild steel. I didn't think it would be a problem so good catch. My goal is no loose nuts and I was hoping to skip the step of welding nuts to the plate.
Yeah there's no good way around it unfortunately. Using higher grade alloy steel adds cost, as does heat treating it. Best is to just add a proper nut, either loose or welded. But you can get un-plated weld nuts so at least you don't have to grind the plating off before you weld them. And 1/4" would be plenty thick if you're not cutting threads into it.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
No shade at LOD, I applaud them for providing something and being one of the first, but I couldn't help it.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount trickplates
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
So they’re like a threaded backing plate. Nice!
Are your welding the spacer on the brackets to protect the crumple ridges?
Anything that bolts to the factory horns should bold up with the plates. I wanted to do away with futzing around with nuts, so there's three 1/2" nut plates.
It is designed to be 100% bolt on, but can be welded as well if desired. The only DIY part will probably be painting, I'm leaning towards providing them in raw steel.
The brackets themselves are 1/4", which is still a lot of beef, but the nut plates are 1/2".
chtucker
Kirkland, WA
FJ Cruiser
The CAD work is done and I'm super stoked, the TrickPlates are going to be bombproof. If I submit the files now there's a chance the prototype shows up before I leave for Moab but I don't want them sitting around a week if they miss me.
The question is before I can commit to a batch, what is the ultimate reinforcement kit worth to you? As it stands now $250 a set is a possibility - raw material costs alone are killing me.
In for a set
Tricky Dick
Dick
PNW
Dusty brought up a valid point about the threaded plate so I might have to revisit that. But I want super tight clearances so there's no deformation.
Yes, the crumple standoffs will be welded. Futzing with washers made that a priority right away.
shawn6107
Shawn
Tuttle, OK
Ford F250, Ford Expedition Max, Chevy Silverado
Love that plate that wraps around the bottom of the frame. I’ve been thinking about welding something similar onto the LOD brackets when mine come in.
I still haven’t got the bumper off for various reasons but now I’m probably going to wait for the brackets to get here so I only have to do it once. I will get everyone pictures and measurements when I do.
GreyZ
Gulf South Louisiana
Have you looked at having inserts put into the part during the laser cutting? I know we use a lot of SendCutSend parts with the Pem incerts installed by them. Not sure how the cost would break down for those parts though.
Deleted User 5719102
Who's
On a Lake
22 2dr
I'm going to start hacking on them as there are several things I would have done differently.
Oh shit, you are going to have to change the thread title again.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 892147218-Meme_0202
Tricky Dick
Dick
PNW
I'm concerned about the strength of those inserts, I'd have to see the calcs on them. Probably going to end up with weld nuts.
Who's
On a Lake
22 2dr
Yes welded nuts would be optimal. Just don't put your nuts in a vise!
broadicustomworks
Hanging Rock, North Carolina
This is the surface the mount ears sit on, without the spacers it's not flat and solid.
Several more pages from here to the end but wanted to say thanks and kudos @Tricky Dick for this post (and the one prior showing the spacers).
My first iteration/install of my mount, I missed them as well.
I had everything on and tight, but it just didn't look right to me.
I didn't like the way the mount sat against the recovery hook plates.
Then (uncharacteristic of us guys) I consulted the directions again, took a look at the hardware and found the mistake.
Unbolting of everything again, but because stubborn is gonna stubborn, I fought to get them in position without a total removal of the bumper or mount, just really loose bolts.
Glad you found the mishap, but in the end a little extra stiffness and support on those horn ends and mount are going to net some strength.
And yes, one of the greatest threads in a while on here.
Quite a bit of helpful info in these 23 pages (or the 13 I have read up to now).
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
I might have found one of the very few benefits of the "Capable" bumper, no need for spacers as the front brackets are flat. Didn't need the spacers when I installed the RC high mount.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 20220920_093303 (1)
BroncoJoerg
Joerg
Saugus, CA
Velocity Blue Badlands
Key words being "one of the very few"...
Status
