CitrusBronco
Everglades
Citrus county, FL
Everglades
Is your engine head and coolant temp higher due to the intercooler being in the way releasing its heat in front of the radiator?
Is that extra heat at these locations not a concern?
Ducati1098
Ducati1098
No. Haven't noticed any difference in coolant temperatures.
Intercoolers in front of radiators are really nothing new. Lots of vehicles have similar setups without issue.
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
I can also back that up. I live in the hot south and coolant temps are no different in the summer months.
Squatch
Which hidden winch are you looking at? I was thinking about doing one also now that I have all the room
The Hammer Built hidden winch setup. I haven't had any issues with my Rough Country mount, but it limits the clearance some, etc.
Ducati1098
Ducati1098
Probably won’t work for me unfortunately, because I have nowhere to relocate my ACC module to.
CitrusBronco
Everglades
Citrus county, FL
Everglades
I know this is pretty normal, I asked since I noticed on your pictures that these temperatures rose while the others fell.
Still within acceptable range, it’s just something I noticed.
Ducati1098
Ducati1098
One recording the Bronco was just running for a little longer, that's the only difference in coolant temperature. Coolant temperature will always rise when you do a long WOT pull. As you can see it goes up on both recordings, not just the high mount
swamp2
Hoping for a Raptor version. Sounds like more complicated packaging/flow paths.
Ducati1098
Ducati1098
Yeah I would agree a little more complicated with the dual inlets. Should still be doable though with the right design.
CarGuy
New Jersey
2023 Ford Bronco
Are you seeing the fan on more often or longer to keep things cool? Also, do you have to remove the shutters?
Ducati1098
Ducati1098
No not at all. There’s really no need for it to come on more often because the temperature isn’t climbing faster or getting any hotter than it always has.
But yes, the shutters have to be completely removed.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
But those vehicles have cooling systems designed to handle the extra heat from an inter-cooler being in front of the radiator.
With as cheap as Ford has become, I wouldn't be surprised that they gave the Bronco "just" enough cooling for the stock setup.
