CV Boot came off
Leeboy8500
Lee
Calgary, AB
2025 Bronco Badlands SAS
My CV boot came off font passenger while off-roading yesterday. Hopefully the joint isn’t cooked, but it didn’t sound good by the time I limped it back to the highway for a tow.
Is there anything that can be done to prevent / protect against this happening again?
GI_Jo_Nathan
Jonathan
Just curious what's your setup? Stock suspension or some sort of lift?
Leeboy8500
Lee
Calgary, AB
Ratfink33
Chicagoland
2024 Bronco Heritage Limited 2 door
Badlands SAS with HOSS 3.0. I have the 2.5” Zone Offroad levelling kit with OEM tires and wheels.
Does that kit come with new upper control arms?
contented
Karl
Central Fl
BMW M2 Competition
From your description, it will likely need replaced. If you’re leveled/lifted 2.5” above SAS, the likely cause is your cv angles are too great. Can you post a photo looking straight in, parallel with the ground showing cv and tie rod angles.
AB8DT
Ron
Cedar Springs, Michigan
www.qrz.com
23 Bronco 4 Door HLE / 2024 F150 Crewcab
Running 37" Toyo Open Country MT with Icon Stage 2 lift I had the same issue coming back from Windrock TN with the boot sliding off and getting debris in side the CV. I had to have both CV shafts replaced under warranty. To avoid this in the future I picked up inner & outer high angle boots from Poly Performance.
https://www.polyperformance.com/rcv-high-temp-orange-boot-for-front-ifs-axles
Ford Bronco CV Boot came off 20260404_124545
Ford Bronco CV Boot came off 20260404_124602
I had a stick come up from the mud and poke one of mine off. Was annoying. It started clicking a day or two later.
I know folks have replaced just the boot. From what I recall, the OEM boot was like $100 (try MB3Z-3B436-B), and you could buy the entire OEM CV for about $150 and not have to mess with cleanup, grease, or the possibility that it was damaged and just isn't presenting yet.
Some people have found aftermarket boots to fit for much cheaper - I don't know of one though.
-- I just went to look at CV prices, and appears they have went up significantly - running around $350 right now. You can get the Ford Performance Painted set ($400) for about $50 more than a single CV.
As far as protecting it - CV angle as everyone here has suggested plays into that. Beyond that - ... not really. Maybe LCA skids might help if it was from something exterior (like mine was), but even that's not a sure thing.
GI_Jo_Nathan
Jonathan
If it is in fact the CV angles that are the problem, a diff drop may be your best insurance.
If you are running a 2.5" Zone leveling kit that includes Top Hat spacer and or one on the bottom of the strut then this is a lot of extra droop. I'm running a 1.5" Zone leveling kit with spacers, but I'm also running a broken Innovation diff drop. I'm running this on purpose specifically for the extra droop along with my Badlands non-sas struts. I have not had any issues.
Leeboy8500
Lee
Calgary, AB
I'm considering the Ford Performance Upgraded axles. Does anyone have any experience with this or know if this might help with the problem? Ford notes that they're designed for for more extreme angles.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
They are same as stock, just cheaper. Your lift might be the problem.
GI_Jo_Nathan
Jonathan
I assume we were talking about the $2000 something dollar ones not the $400 ones?
Leeboy8500
Lee
Calgary, AB
Correct. M-3429-BU which supposedly has more articulation capability.
Also looking at the RCV Performance axles but seems like the Ford Performance Upgraded ones may be better manned on road.
No, Ford Performance also makes an upgraded one M-3429-BU vs M-3429-BR which is stock but painted. BU is $2500, BR is $400.
Leeboy8500
Lee
Calgary, AB
Interesting, didn't realize Ford rolled out new expensive axles. I wonder what makes them worth RCV or spicer money...
Yeah, very good question. They're actually more expensive than RCV.
Since my Bronco is currently sitting at the dealer undriveable, I'm leaning towards just sucking it up and having them put the Ford Performance Upgraded axles in so I can get it back in reasonable time. It'd have to sit there at least a week I'm guessing if I wanted to wait for the RCV ones.
I was hoping someone might have some insight into them!
GI_Jo_Nathan
Jonathan
If it was me I would do the Ford performance painted axles to get back on the road, you could buy a couple sets of those rather than the upgraded unknown axles that may not really solve your whole problem. I really think a diff drop is what you need if it's due to the excessive droop.
