swamp2
swamp2
I did this on my R&D Raptor after seeing your post, for the community.
Red line (COBB HOT Truck!), Pull #20
Wow, fantastic.
Does the "#20” above literally mean the 20th consecutive pull???
Results are impressive and entirely consistent with my prior data (although obviously less difference than when the truck is moving). Your data here should show about a 25 crank hp (6% or so) difference COBB vs. stock (for a stock tune). Again rule of thumb is 1-1.5% more power per 10 °F lower MCT.
The only very minor nit seems to be you are missing the Stock IC + hot run. That compared to COBB + hot was the crux of the prior fellows obsession 🤣.
GooseTuned
Winfield
New Mexico
All the Raptors, Explorer ST, F150, and some other toys
Wow, fantastic.
Technically it was the 22nd pull, but we can call it 20 for data's sake haha
The stock tune is pretty aggressive pulling power to keep things safe
an intercooler helps a lot
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
damn thats crazy. swamp2 you may wanna quote goose's work in the op, lots of good data points between you two
swamp2
swamp2
Good idea. Am doing now.
Jfdeno
Vienna, va
1970 bronco, 2 FE Broncos, 22 Braptor
Does anyone know the correct part number for the Actuator Temp Control? Ford Parts states
RB3Z-10884-A but that does not fit on the Raptor 3.0L
My shutters are stuck open (I guess ok) but I am receiving a "powertrain module lost communication with active grill shutter" message- as a result, cannot get high boost power with the turbocharger.
thank you
Ford Bronco Cobb Intercooler for Bronco Raptor - Tested/Data - Amazing Performance connect_20260226_173223_Gallery
Ford Bronco Cobb Intercooler for Bronco Raptor - Tested/Data - Amazing Performance actuator_20260226_171024_Messages
Ducati1098
thank you
Can you be more specific on which part it is you’re actually looking for?
The connector you’re showing appears to be for the upper shutter motor, but the part you have is the lower motor.
Which one do you need?
Jfdeno
Vienna, va
The upper shutter motor. Having difficulty finding the part number
Ducati1098
Can’t get it separately. Have to buy the whole shutter assembly. Everything with a green triangle next to it in the picture below.
21-24 Bronco Raptor: PB3Z-16138-B
25+ Bronco Raptor: SB3Z-16138-A
Ford Bronco Cobb Intercooler for Bronco Raptor - Tested/Data - Amazing Performance IMG_9963
Jfdeno
Vienna, va
Thank you. Problem solves. Appreciate your help big time. Now sit a wait until the part comes in :)
Jfdeno
Vienna, va
I thought if I just left the shutters open and unplugged the actuator, my problem would be solved. However, getting no boost...check engine, etc. So I guess I need to replace the actuator
Sir915
Shawn
El paso
2023 Bronco
I've seen a few post this issue is this just a luck of the draw type deal? I want to switch to the cobb but this issue is a deterant
swamp2
swamp2
With Cobb the front motorized shutters stay in place and the passive rear ones are not used. It's a simple drop in install.
Sir915
Shawn
El paso
2023 Bronco
Looking to pull the trigger on this now
GooseTuned
Winfield
New Mexico
These are OOS for 9-10 weeks. But I'd recommend getting your order in asap
