Clueless on what PSI is reading...
Wallysdog
Champlin, Minnesota
2014 GMC Sierra
When looking at the gauges on my OB I see a psi that reads 0.0.. What exactly is that reading?
AKBronc49
Russ
Anchorage, Alaska
Turbo boost.
rtazz17
Connecticut
2022 Ford bronco big bend
More specific? What guage? Boost? Boost is zero when at standstill or not in gas
Gtrekker
Gary
Lol.... if it's the one gauge with psi and not four of them it's the turbo boost gauge.
That's the one that digs into your wallet. The higher the psi the more you will pay at the pumps!😎
I've been told it can activate the blue light sensor in the rear view mirror...🤔
AMC Ape
Bronco L
Oregon
2023 Bronco Badlands, 2021 Hyundai Tucson Ultimate
Is this gauge suppose to be available on the 2.7L? I have a 2023 Badlands 2.7L and I can select it from the options. According to the owner’s manual it’s only a product of the 2.3L. Wondering if it is a software glitch or in there by default.
Mikesmallcrawler21
TN
14 F150 screw
I have 2.3 and 2.7, both come with turbo boost gauge in the instrument cluster.
Gtrekker
Gary
I'm thinking you need to post pics and maybe proof of your Generation...
Are you being a troll????....(n)(n)
Baja Bronco
2Sun AZ
No he’s not. I’ve got the same thing, can’t figure it out. Reads 0.0 psi. I know it’s not the tires or boost, I have those gauges.
AMC Ape
Bronco L
Oregon
The guy above you confirmed and answered. I’m not trolling, I’ve never owned any gen Bronco, and this new 2023 engine is so busy I dont know what’s going on. Yes I’m a lil ignorant but I’m not a crazy liar.
Gtrekker
Gary
My bad.😢
da_jokker
Jeep Wrangler JKUR
There are two screens you can read your turbo PSI. Both of them are in that dashboard screen (behind the steering wheel) and not on the infotainment screen.
0ne of them is the top gauge in a set of three or four other cages that show you transmission temperature and oil temperature and battery voltage.
Then I believe there's a separate screen that shows more of a round dial and is just turbo PSI.
And FYI, you do not need to get into the throttle very hard and you should register something. Even light acceleration will register 1-2 psi.
And I'm sure it's obvious, and goes without saying but if you see a picture with 4 PSI readings next to tires....
Side note: I don't know about the 2.3, but the 2.7 can go between 0 - 18+ psi
Techun
Pa
BD, 2.7, MIC, 4dr
help!
My car came with 4 turbos and they're all stuck at 38psi!? Can I fix this with a different engine oil?
