lowest PSI on road?
ghazi223
Ghazi
canada
bronco wildtrak 2 door
hi, every time I’ve been off-road I have not lowered the tire pressure on my bronco because I’m scared of ruining the tires when I’m back on road, since I have no compressor (getting the american advanture labs one soon) so there is no point in getting a portable one right now.
tomorrow morning im doing some moderate offroading and want to lower the tire pressure, but i will have to drive an hr back to the nearest pump (costco)
whats the lowest i can do for onroad driving?
Fmuguira
Frank
Idaho
Jeep TJ
Tire size makes a big difference along with load range … you might post that to help get you better responses.
Depends on speed more than anything
That said, if I'm just going up doing fire roads, I'll drop to 25 psi, and still do 50-55 mph on the roads getting there and not worry about it too much.
I wouldn't get on the freeway though.
If I'm doing rocks and stuff though, 15-20 depending on where, I don't air down until I get to the trail, I don't do more than about 30 mph (asphalt or otherwise), and I carry my air compressor with me.
SierraBronco
Surely someone in your group has a compressor?
If you want to stay on the safe side you could look at the load rating for your tires and adjust from there. 35 psi is the cold pressure for max capacity. I run my factory sasquatch tires at 32-30 psi on the street. Wifey's 40 inch tires, while still being a C range tire, only need 24 psi for her bronco. When we go to an event for wheeling we only air down once. Checking the tires with the flir after a half hour at 45 mph and tire temps were under 90F, but again there are other considerations to factor in.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
At the Moab Off-Rodeo, they set all broncos to 20 psi I think (read 23 while hot) and then we drove 20 miles on pavement to get to the trailhead. They only advised us to keep below 55 mph. This was with the Sasquatch tires.
SHANUT
Craig
Hermann, MO
I’ve aired down my load range E BFGoodrich all-terrain’s to five psi and there’s hardly any deflection because they’re such heavy duty tires. I would never run them that low, but it definitely depends on what load range tire you have on your machine.
ghazi223
Ghazi
canada
it’s factory sasquatch tires
i have them at cold 39 psi planning on doing 15-20 for tomorrow, its only an hr drive on that low of psi on pavement.
so i think should be good but not too sure
bassist
Northern VA
2024 Bronco Badlands w/Sasquatch Package
You don’t need to drop to 25 on fire roads.
My commute involves several miles of dirt/gravel with a mixture of potholes and washboard surfaces in some places.
I run at stock air pressure. Not really a big deal at all.
bassist
Northern VA
Ummm….you do realize you don’t need to go to Costco to fill your tires, right?
Gas stations have pumps, typically free.
ghazi223
Ghazi
canada
true but it is kind of a remote area so closest gas station might not have a pump, first time going there so not sure but i will keep that in mind
ghazi223
Ghazi
canada
im going into soft sand, not just fire roads
