PSI tire pressure on 35's?
Zeaks
Cen Tex
24 Wildtrak/19 FX4 Exp Max
Mine were showing around 45-46 when I purchased my Bronco. I dropped it to 35 cold, it's usually around 37-39 after driving around. One is usually a psi higher than the others which bugs me so I need to play with that one. Seems good at this pressure.
Mjasi3
Chicago
Im running at 36 cold - need to do chalk test
So, different tires will have different "optimum" pressures - various sidewall ratings, materials, tread, etc.
Most light duty vehicles (and the Bronco is one of those) run around 35psi as a baseline, +/- from there.
My MT Baja Legends started out at 35 - they were a bit stiff on the Hitachi OEM suspension. I lowered them to 32 and it softened up a good deal. I just got new coilovers, and I just bumped them back up to 35 to see how they ride there.
helifino16
Ron
Mount Sinai, NY (Long Island)
I use my Air gauge and make sure that I have it up to 100%.
Ford Bronco PSI tire pressure on 35's? 1714403621545-fd
toymaster
Leonardo
Wyoming
2023 Badlands
32 psi here. 25k miles so far and wear is normal. I run very light weight.
Fordified1
Bob
Mid South Texas
I’m running my 35x12.5 on the OEM Sasquatch wheels at 40 PSI. I believe the tire says 50 PSI is where they “should” be at.
They only “should” be at that level if you’re carrying the max load rating of the tire. That’s the max pressure rating for max load.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
What would you recommend as a PSI for tires with a max PSI of 50 then? Is 40 still too high? These new tires add an extra 100 lbs or so to the vehicle vs. my OEM Goodyears.
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
I set mine for comfort especially whenever I'm not loaded for an adventure. I set them at 32. The ride is much nicer.
Fordified1
Bob
Mid South Texas
Yes, too high, especially for a 10-ply on a light Bronco. I run 35 cold. Ignore the pressure they get to when hot. Your TPMS will let you know if one gets lower than the rest. Always set your pressures in the shop or shade before getting them hot.
I would probably run a smidge less than 35 in mine, but they get noisier with lower pressure.
There’s a thread somewhere about how to chalk test to see if your tires are making even contact on the road with different pressures.
604Bronco
British Columbia
www.bronco6g.com
What tires are you running on your Bronco?
Broncotrax
NORCO
AJ Trudeau
Winnipeg, Manitoba
2022 Bronco Badlands
It's all clear as mud but after that said, I'm going to reduce from 40 psi to 38. With colder weather approaching, I'll see how that works. At 40 psi (cold) the 35's runs pretty stiff. I'm looking to improve the ride so I'll see what happens.
cjacobalpinetx
Alpine Texas
2022 BMW X5, 2023 Bronco Big Bend
Tire PSI at delivery is dome by tje dealer.
Use the PSI on the door as tiyr guide its there to help you. Provided you have not changed the tires.
if you have changed the tires use the PSI tange as provided my the tire MFG.
I run 40psi in my aftermarket tires as its the minimum suggested psi
Yoo low of PSI will increase roling friction which will over heat the tire and could cause failure.
adam1991
VW GTI (2)
Mine came from the factory at 46psi. I lowered them to 39, but haven’t changed them from there yet to compare.
My 32s are specified for 35psi, they came from the factory at 41/42psi. Whoever did the PDI at the dealer never found that...even though it's ON THE SCREEN AND THE APP...
