45 PSI Tire Pressure too high?
wgr75
Gary
Windsor, Ontario, Canada.
Bronco 2024
Just a quick question regrading tire pressure. When I made delivery of my Bronco the tire pressure was set at 45 psi. I think that might be high. Should I be concerned?
gwp
Greg
Winchester, Virginia
Harley Davidson FLTRUSE
Broncos are typically shipped at higher tire pressure. Reduce it to 39 or whatever your door jam sticker says. The dealer should have done this in prep.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
It's fine, but you can lower it. I'll admit I had mine at 45 PSI during my 10 hour road trip to Michigan last week for that sweet sweet 23.8 MPG.
Anyway, it's common for tires to be overinflated slightly for shipping purposes. As everyone else said, it's something the dealership is supposed to correct during their pre-delivery inspection.
Ninjak
Miami
I run 40psi
gutshot
Kelly
ohio
2023 Bronco
I'm running around 30 psi cold. I was running about 33-34 cold and it's starting to cup in the middle meaning the tire pressure is too high. I'm at 28k on stock SAS tires doing a 5 tire rotation every 5k miles.
Chalk test is really the only right answer here - whatever pressure gives you good, even contact.
That’s a different number for different brands/models of tire
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
Not to mention 2dr v 4, 2.3 v 2.7, steel bumpers v plastic, skid plates v none, etc. Etc.
wgr75
wgr75
Gary
Bronco 2024
Thanks. I'm heading to Florida next week for week. I my just leave it alone and see if I can get some mpg.
Tilzbow
NV
GM Sierra Diesel Pick Up
45 PSI will cause excessive wear in the middle of the tire. You should at least lower it to whatever the door sticker recommends.
PlayTime
Patrick
SoCal
'23 2dr 2.3L OBX non-SAS Eruption Green
OBX stock I run at 35, but mine too was delivered with a crazy high pressure...
