Check brakes alert
GorillaGrapplr
Tim
Wheeling WV
2021 Ford Bronco Badlands 2.3 Area 51
I’ve been reading there are a lot of issues most leading to vac. Line. But when it’s vac line most are reporting firm pedals. I am getting this alarm but brakes work fine. Any thoughts?
Sir915
Shawn
El paso
2023 Bronco
All depends on your motor I had this happen on my old 2.7 and they had to run though a pen out and ultimately replace the whole dam assembly for the master cylinder
Vacuum only applies to break systems on the older 2.3L system.
There was a TSB or something for a loose vacuum line for … MY22s maybe? But vacuum isn’t a common issue even on Broncos that use it.
2.7 and the MY25+ 2.3 all have electric brake systems. I’d try charging your battery overnight and see if it clears
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S, 14 JK Rubicon
Had this happen on my 2.3. Easy fix, expensive part not covered under ESP. The hard pedal will show up eventually. I think the problem is in the check valves; I believe they are open under vacuum, closed under boost. If you go to apply the brakes at just the right time you will have no vacuum and a hard pedal. Dealer had the part in stock.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
2022 2.3L.
Had this happen while on a roadtrip, on interstate at cruising speed. I’m guessing the constant low boost (3-8psi) was afflicting the vacuum system because brakes hadn’t been used in over an hour.
The revised Vac Line/Diaphragm solved the issue. Easy swap, three connections I think? Did it with hand tools.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
2022 2.3L.
how much is the part?
brauncoboy
Jared
Ford Explorer Sport Trac
what part number should I be ordering ?
Dirtrider
Bruce
St. Louis
Honda Ridgeline, Super-C Motorhome
'22 2.3, MT Bronco. I complained about a soft pedal, brakes worked fine. Apparently there was a TSB on the vacuum line and the dealer replaced it (they said that it had a vacuum leak) but I don't believe it had any effect on the pedal feel. Maybe I've just gotten used to it but pedal feels more 'normal' now.
Boreal
Colby
MB
2022 Badlands 2DR
Tacnav#1
Gene
Gulfport, MS
Bronco Badlands, F-150, Dodge Challenger R/T
I got the same alert on my 2022 Badlands just a couple weeks ago. It turned out to be a faulty microswitch in the brake reservoir.
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
I have this recurring issue on my 2.7. I get U codes for loss of communication and also had the reservoir replaced due to a bad micro switch. Same check brake message appears every now and then but absolutely no other symptoms. Ive been suggested to replace the battery but currently out of warranty and havent had battery issues at all so just living with it for now.
