Car wash etiquette please
BroncoChallenger
2024 Bronco
These threads go off the rails sometimes but that keeps it interesting. I use the auto car wash touch-less all the time for my Braptor. No leaks and MIC top is all good so far.
Yeah ours has gone through a couple times...but since I learned about the recommendation I have stopped. Hasn't cracked yet but why risk it?
stevenstommyboy1
Thomas
Menasha Wisconsin
2023 Bronco Raptor
It’s the easiest option for me and it’s touchless so no issues and no cracks or anything like that. Just the random drip of water every now and then. But that’s mostly after a hard rain.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco, '25 GR86 w/Performance Pack
I forget some states don't have automated car washes, I'm used to etiquette being having $$$ for the tip
broncobase1
Lincoln
22 Bronco Base
Either way is a lot better than leaving it on the ground.
RealTruck
Lux Sponsor (Level 2)
Ocala, FL
N/A
23OBX2.7
AB Canada
2023 Bronco
I use semi truck wash thats near downtown great pressure, angle wand head for undercarriage and fender wells and supurb spray pattern dont even need brush.
There is no etiquite at amy car wash that Ive ever been to just a bunch of animals jostling for position and 4th world uber drivers using them as persoanl detailing bays while cars are lined up to use.....thus the semi truck wash.
BroncoChallenger
2024 Bronco
Do you brush your teeth by just rinsing your mouth with toothpaste and water?
A bit of apples and oranges there. Our teeth aren't painted.
Desmolicious
SoCal
2025 Bronco HE, MX5
Akshully I just washed my Bronco using only the tire/wheel brush for the tire and wheels (!), the high pressure soap and high pressure rinse for everything else.
perfect - and quicker and cheaper than if I also used the brush as I always need to add extra coins otherwise I run out of time with that.
Sweet Mabel, I have seen the light!
Bronco21Maybe
Justin
2015 F150, 202X Bronco, if it's ever built
If you use the brushes at the car wash to brush your teeth, eventually you look like this:
Ford Bronco Car wash etiquette please 1777487908728-dj
