Soft top touchless car wash?
RainbowStix
A Big Island
Toyota Tacoma
The soft top shouldn’t be run through car washes or have any type of soap on it at all
It’ll hold up fine, but it’ll fade a lot faster overtime (count on it lookin gray within a year, 2 max). you might also notice scratches on your windows if it’s a brush wash.
If you want to keep it looking new long term, give it a good cleaning with actual soft top cleaner, a brush and spray some 303 fabric guard on it once or twice a year.
Having a soft top for me actually makes it way easier when washing because you ignore half the vehicle and don’t use a foam cannon.
BarryHo
Barry
Winnipeg MB Canada
2023 Bronco
Two main concerns in touchless high pressure auto wash, one the pressure getting past the seals above the doors, as they are not very air tight, even in cross winds, two the chemicals used are very hard on the soft top material. My 2 bits...
Ninjak
Miami
I have run my Bronco through a touchless with ZERO issues. No leaks, no fades and I am in the very bright S. FL sun. Now I never use the other type of car washes. All my vehicles go through the touchless, sans the 68.
frdfan
Greg
LaVista Nebraska
22 BB Sasquatch HPRM
No issues here either.
Happycampinman
Ford Bronco
My two cents. Living in Michigan and the massive amount of salt that is poured onto our road during the winter I have no choice but to wash the Wildtrak frequently. It’s too damm cold to pull the buckets out, so I found a local Touchless Car Wash and it did a decent job of removing the salt grime and film off the vehicle. No leaks, no damage. Just a fairly clean vehicle.
bhb
N NJ
Same.
I wanted over a year before I gave in, but I found a high end car wash that has done a good job. I still wash it myself most of the time, but 1-2 times a year to keep salt off it and its been fine.
