Bronco Raptor Spark Plug help
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
133 in lbs for a spark plug!? That seems way too much! ? Can someone confirm please?
Its INCH pounds, so about 11 FOOT pounds.
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Yep, I can practically hand tighten them to that torque spec. Was really surprised how little force it takes to get to that torque rating.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
Just did mine this week, it took about 40 minutes. The only annoying part was the foam cover on the pass side.... Makes me wonder why it even there lol...
this was MUCH easier than my 12' raptor with two plugs / cylinder and the bottoms hidden behind the spring towers under the engine..... truly ugly....
GooseTuned
Winfield
New Mexico
All the Raptors, Explorer ST, F150, and some other toys
It's there for noise reduction. The HPFP is LOUD under normal operation...Ford doesn't want people thinking they're truck is Broken
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
Appreciate the note, I have to admit that between the wind noise, the stereo and my mud tires I couldn't hear a locomotive horn outside much less my own engine.
swamp2
@ZFGracing , gap advice for the Ruthenium plugs in a Raptor on E50 Race tune? I will also run a 91 E10 race tune, so hopefully a single gap will work across your various tunes.
Spooled
Republic of Texas
Raptor, Model 3
I gapped mine to .028
That gap will be fine for both
GooseTuned
Winfield
New Mexico
026-028 is all you need. I've ran that for almost 1yr, stock turbos, and bigger. 91>E85.
Ape Factory
Michel
They're $9.32 each on Rockauto.com.
dougcjohn
Doug
Iowa
‘24 F450 Limited, ‘25 Bronco Raptor, ‘16 Smart Fortwo, ZX12R
