zombie
New Brunswick, Canada
'21 Bronco '22 Mustang GT PP 06 Viper SRT10
How about how to turn the idiotic chime that chimes multiple times when you set cruise!
Can't say my Bronco has that... something to do with active cruise? (mine is basic cruise control)
Scopebit
Troy
Tricities, Washington
TXBronco1313
That’s amazing thanks so much! This reminds me of the GTA cheat codes I used to keep handy while cruising the streets of San Andreas lol
AttackGuy64
Denton, TX
2019 Toyota 4Runner
The ultimate cheat code….
Up up down down left right left right B A select start.
2 player infinite lives. Otherwise, B A Start.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Clutch and throttle or Brake and throttle?
Clutch and Throttle. Hold To the floor. Press and hold the start button for 5 seconds. Will crank without fuel in order to build oil pressure and fill the oil filter
@swooshdave - you can’t start this manual with the clutch engaged (with the exception of crank in gear during 4L)
Clutch and Throttle. Hold To the floor. Press and hold the start button for 5 seconds. Will crank without spark in order to build oil pressure and fill the oil filter
Got it - it’s different for autos and manuals.
Ducati1098
These probably aren’t modes people need to be in (aka don’t blame me if you mess something up lol) but just in case you’re curious…
Bezel diagnosis and speaker walk around test:
Ignition on, audio in AM/FM mode
Simultaneously press and hold the on/off button and the seek down button
Dealer Test Mode (Engineering Test Mode):
To enter the IPC engineering test mode or dealer test mode, begin with the ignition off. Press and hold the RH steering wheel switch OK button. Ignition on and continue to hold the button for 5-8 seconds until the display indicates Engineering Test (ET). Press the up or down arrow buttons to navigate through each of the display windows. To exit the IPC dealer test mode, press and hold the OK button for 5-8 seconds or place the ignition in off. Each down arrow button press advances the viewing window to the next set of items.
