HolidayDog
Everglades
MT
24 Everglades
Everglades
I tried the seatbelt chime one…I could get the seatbelt light to indicate I was following the sequence but when I restart the car I still hear the chime.
or maybe the chime I hear isn’t the seatbelt chime…it sounds like a pleasant repeating doorbell when I start the Bronco. It chimes 3 times I think.
It kind of bugs me even more knowing it could be turned off.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
If you had posted this yesterday I would have been like... :unsure:
Some crazy stuff there. Waiting for the "rub the belly" step.
Funny. I use this phrase along with simultaneously rubbing the top of my head to describe turning off the seatbelt chime to someone who hasn't had the pleasure of doing it.
Ducati1098
@Brian_B - Might be helpful to edit your original post to include some context for what each “cheat code” is. For example, no idea what “Bezel diagnosis and speaker walk around test” is. Could be helpful to add that context for each one.
I agree. Will do so when I figure it out myself
Bezel diagnostic mode contains a ton of mostly useless information that nobody will ever need.
The main reason I posted it was for the speaker walk around test which it goes though at the very beginning. It basically emits a noise for each speaker one at a time. Could potentially help if someone had a speaker that they thought wasn't working correctly. There are also some screen tests and radio/satellite signal tests in there.
wazuu00
Ryan
land o lakes florida
f150
Seat belt chime worked for my f150 lightning… thank you!!! Will be on job sites doing 9mph and the damn seatbelt warning never stops. If only there was a way to reduce the blinker/turn signal volume without forscan
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
I changed my battery a few months ago and did not know about the reset. Should I do it now? What difference does it make?
BMS tracks amps in vs amps out and total amps to help track battery health and capacity. Old school just looked at voltage and it either started or it didn’t - but that won’t account for battery age where the voltage can drop steeply under load. Tracking amp hours helps the system account for that.
It probably won’t hurt anything either way you go - but if you start noticing it go into deep sleep often out of the blue even though it has a good charge that may be part of the reason
ericwmedic
SE Michigan
17 Focus RS NB
Don't forget the Voice Activated Remote Start feature.
1. Cycle the ignition from off->on->off 14 times within 12 seconds.
2. Tap the brake pedal in the following pattern: On 2 seconds, off 1 second, On 4 seconds, off 2 seconds, on 8 seconds, off 4 seconds, On 16 seconds, off 8 seconds. Do that twice.
3. Walk around the vehicle three times counter clockwise
4. Open all doors, including the tailgate, hood, glovebox, and center console
5. Walk around the vehicle 3 times clockwise
6. Close all the doors
7. Press the lock button on your keyfob
8. Press the remote start button on your keyfob twice while saying "Engage Thrusters".
Voila, you've just successfully remote started your Bronco via voice controls!
Please note that these steps have to be done in order each time, or it won't work.
swooshdave
Portland, Oregon
Mustang
Might have been funny on Monday...
akturbo
Seattle Eastside
'21 Bronco, '24 2D HLE (wife's), 3500HD Chevy, Rav4Prime, Turbo Skidoo
The ultimate cheat code….
Up up down down left right left right B A select start.
I gave up, this is best I could get Bing Image Creator to come up with.
Ford Bronco Bronco Cheat Codes List OIG1
Ford Bronco Bronco Cheat Codes List OIG4
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
I would love a code to decrease the sensitivity of the auto headlights.
My ceramic tint has my headlights turning on when I come to a stop in a shadow in broad daylight.
swooshdave
Portland, Oregon
Mustang
I think I've heard that being in Forscan.
Turner00
Jerry
Akron, OH
2023 Badlands SAS
I've tried the seatbelt one a few time, my seat belt light never goes out. Am I missing something?
