Best Mode for Highway MPG
GreyZ
Gulf South Louisiana
Eco 2wd will be best. It also changes your shutter flaps in the grill for better aerodynamics. Youll run a bit hotter, which is a good thing for efficiency.
An often overlooked element is wind speed. An 8mph tail wind will give you SIGNIFICANTLY better gas mileage than going the same speed with an 8mph head wind.
I normally target 20mpg on the highway, but check wind maps for long trips. If I have a 5mph tail wind then I can cruise at 80 all day. If I have a 5 mph head wind I slow it down to 70.
Black_Stallion13
Cincinnati
Tacoma
If I set the cruise with rpms under 2k (I believe about 65 mph in 6th gear, manual) I get about 26mpg freeway with standard Big Bend/OBX tires in normal mode at the suggested factory PSI. I feel like there's not much you can really do other than drastically limit speed and air up if you opted for 35s.
JL8jeff
Ewing, NJ
I just did a run to the beach yesterday to catch the boat races and with my 2.7 base 2 door Sas with 35x12.5x17 BFG KM3 tires I averaged right around 21 mpg using normal mode. The biggest chunk of driving was in the 55-62 mph range. When I hit the highway and got up to 70-72 mph the mpg went down a little. So the actual speed will have more of an affect than which mode. My previous 2 tanks averaged around 18 mpg with just around town driving and not getting above 50 mph. I just hit 1300 miles so I might still be breaking in the engine.
PrepVet
North Central WI
A bunch.
I have noticed exactly zero difference no matter what "mode" you pick for MPG. Personally I think the "eco" mode is a marketing add-on and it does absolutely nothing in the real world.
AZ_Liberty
2007 Expedition
Modes will have no effect on the freeway, as you are theoretically already in your top gear.
If the freeway involves mountain passes, just remember to lock out the top gears when going uphill to prevent the engine from lugging, you will have worse mileage in higher gears with boost than lower gears without boost.
And of course, modes never have any effect on MPG of a stick shift since you are shifting yourself.
KABQ
Aaron
Albuquerque, NM
The only eco mode is in your brain. If your brain is chill, your right foot will be chill. Be alert to changes in traffic flow and lift/coast as early as you can. If you're using the brakes you're reacting too late and missing an opportunity to coast at speed, which is where you'll see the most gains.
da_jokker
Jeep Wrangler JKUR
Yeah wind can make a big difference. I had to drive 150 miles against the wind a while back. 65mph-ish and my boost was 4+ most of the way.
Thank goodness the way back was the opposite and it helped balance my wallet:)
HoosierDaddy
__ Eric
NW. Indiana
The mode where you drive 65 the whole time? it seems like mine gets a little better mileage at 80 than 75 but haven't done enough long trips to be certain. in 10th gear at 70mph on flat ground the engine is basically at zero vacuum, so any increased throttle puts the turbos into boost which requires more fuel.
Staying out of boost is key to higher MPG's on these ECO/BOOSTS.
It's a choice ECO or Boost, not both.
When I swapped my manual Base from 30's to 35's, the hiway mileage absolutely tanked....until I stopped using the top gear.
Dropped to 5th at 78mph, 2700rpm and my fuel mileage actually increased over the factory set up.
72F262
Doug
Charlotte
18 GT350, 72 Mach 1, 22 Bronco 2 Door
Single best thing for mpg. Slow down. Works great in any car. Especially a high riding brick.
I saw about 2 mpg loss for every 5mph I went above 70.
70 was about 24 mpg
75 about 22.5
80-85 about 18-19.5
this was all during a one way drive from ohio to Idaho using 87 octane. Base 2.3 7spd with black diamond 32” tires.
Coming home was worse. Went through the corn states so I suspect a higher blend of ethanol.
I was heading home to KC from the CO mountains and doing 80 on I-70 MPG's were 15-16 with windy conditions. 2.3L 7spd 33" BFG's. My wife gets 19-20 driving in town back and forth to work.....
Tiresmoke410
Ohio
22 bronco, 16 F250, 66 F250, 68 mustang
My rural ohio daily running around comes out to 24 or so in the summer months. Well with the factory base 30” tires. The 32s drop about 1 mpg off the daily running around.
66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
I want whatever mode this has... same mileage I get with my BL 2dr. 🤯
Ford Bronco Best Mode for Highway MPG Screenshot_20230626_202513_One UI Hom
(I know it's a hybrid.. but that's mind-blowing).
Boomee
Bunmi
2 subarus and a honda
Eco 2 wheel drive or normal mode 2. The Eco mode changes the shift points but on the highway I’m not sure you will see any difference. The aerodynamics and heavy rotating mass of the wheels makes the Bronco one of the worst vehicles of its size for fuel economy. We average 17.5mpg in mixed driving with our Bronco and 29 mpg in our Range Rover diesel that is the about same size and also weighs 5,000+ lbs.
Also the range rover is a diesal wich is probably the biggest difference in fuel economy for that class of vehicle
