Best fuse to pull to crank w/no start?
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
EFI or Fuel Pump or something else? Any pic of fuse block showing exact location? Thanks
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
Press accelerator to the floor and push start = crank but no start.....
box986
box986
Paul
NNJ/NEPA
Noremac
East Coast Florida
2021 Bronco Badlands Sasquatch
"flood clear"... push throttle to floor, push start button. it will crank and not start. push button again to stop cranking.
box986
box986
Paul
NNJ/NEPA
& don't press brake pedal at same time I assume?
Noremac
East Coast Florida
Im almost certain you hold the brake in too.. just as if you were trying to start it.. only difference is, holding the throttle down to the floor.
I do this after changing my oil to fill the filter and hopefully create some oil pressure before firing off. If only we had an oil pressure gauge to confirm it on these..
PWillette
Parrie
Maine
box986
box986
Paul
NNJ/NEPA
Thanks all, it worked! (left foot on brake pedal, right foot pressing gas pedal to the floor), press start to crank, press it again to stop cranking.
orion
Jeremy
17' F-250, 17' Explorer
Off topic somewhat, but anyone know why the powerstroke diesels don't have this feature.
I don't drive mine alot, just when towing or when my Bronco isn't available, so it sits. I would love to get the oil circulating on that beast before actually starting it when it sits for long.
swamp2
i certainly agree it is useless to do this post oil change. Ones bearings certainly don't go dry from an oil change.
Now that said, could it be used to get a much more thorough oil change? Use the function with the oil drained and drain plug removed and couldn't you get a significant more amount of used oil out of the engine?
Perhaps then also using the function after such a complete change might make sense?
Ducati1098
It just doesn’t have any diagnostic purpose for a diesel engine.
Using clear flood mode isn’t going to make a difference over just starting the engine. Both will take the same amount of time to build pressure.
KABQ
Aaron
Albuquerque, NM
Please do not crank your engine with the oil drained. Seriously.
