Badge Removal Damage?
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I’m thinking of removing my Archetype Racing script badges. If you all remember from a couple years ago, these took forever to get and were claimed to be of such high quality, but then Archetype Racing went out of business and now I’m left with faded badges. I’m thinking of removing them and replacing with another badge type from Etsy.
What damage to the paint do I risk when I remove them? They are rather large and have 3M VHB adhesive behind them. They are stuck very well. I’m aware of the basic procedures to remove them (heat gun, floss, etc) so not worried about the process but rather the potential paint damage from the adhesive. Will my clear coat be stripped and left with a “ghost” script on the paint?
Thank You
Ford Bronco Badge Removal Damage? IMG_6759
Ford Bronco Badge Removal Damage? IMG_6758
Ford Bronco Badge Removal Damage? IMG_6757
MilesTeg
United States
2024 2DR Badlands Manual/VB, 2018 F-150 Lariat/3.5EB, 2013 Mustang GT DIB
There's a potential for damage, but also the paint under that badge is going to have aged differently than the exposed paint. The paint under the badge will be less faded. Will the difference be visible? Depends...
VehicleNanny
vehiclenanny.com
2025 Bronco Big Bend + 2014 MINI Countryman
If you are comfortable removing the emblems, you are most of the way there. There are products to remove the remaining adhesive residue...just make sure it is safe for automotive paint. A detail supply shop near me sells a Gum and Tar Remover that works great.
If there is any paint fading (unlikely), use a light polish. Good luck!
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
I would think it depends on how long they've been on. I removed some badging from a Jeep I had and the paint was bleached enough you could see the difference.
CalvinT
Calvin
Phoenix, AZ
Blue fades under the sun, but it will be less noticeable with light blue.
I think the OP should try to find an emblem that's a close size match to the Archetype emblem. It's a shame Archetype didn't use better coatings, it's a nice design.
If it were me, I'd look into to refinishing the emblem with more durable coatings. It all depends on skill level and if you bend the emblem when removing it. Or try refinishing the emblem in place.
VirginiaHeritage
Frank
‘25 Bronco HE
Plastic razor blades are a thing too. I’ve used them for removing decals from fiberglass side boxes on trucks.
CalvinT
Calvin
Phoenix, AZ
With that type of adhesive, I believe floss would break easily. You might be better off grabbing some braided fishing line and using it.
That's what I used when I removed the Bronco emblem from the tailgate. That and Goo Gone and patience.
24GTBadlands
IL
24 Badlands v6 (3 inch lift), 24 S650 with PP GT (pre-production), 1971 Mach1
An old one used to be Lighter fluid, or if you do the line method lighter fluid, and let it soak the adhesive for a few minutes, or toss a little bit in-between the emblem and let it soak, obviously clean up the dribble that will always fall.
It's not instant, but it used to be faster than the safe removers, and I have never had it hurt paint.
was also excellent for road tar back in the day.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
I agree with @CalvinT that you could try to refinish them. The script was originally black, right? Get a bottle of Mothers Back-to-Black and rub that into the emblem after cleaning them. You probably would need to use a Q-tip or something to apply. I’ve been impressed at how well it works to restore plastic to black color after its faded to gray.
23OBX2.7
AB Canada
2023 Bronco
heat gun and plastic scraper to get it started should come off easily. A quick power polish will make it clear gloss level look perfectly matched. I debadged OBX first day.​
bc_indiana
Stroppe
Austin, TX
2025 Ford Bronco Stroppe Edition, 2008 Toyota Trail Teams FJ Cruiser
Stroppe
Theses guys have a nice removal tool as well as adhesive removers. Link
VirginiaHeritage
Frank
‘25 Bronco HE
Broncolander
Bruce Wayne
Batcave
Use heat gun with dental floss and you’rs gold, and then apply auto 3M adhesive remover to remove any glue residue. You can also try spraying 3M adhesive remover directly onto the back of the badge to help with removal. I recently removed cured 3M super weatherstrip and gasket adhesive straight from the body paint without any issues using their spray.
The body panel beneath the badge may have aged differently than the rest but it might even out over time with sun exposure
