Are brakes same on all trims / models?
SierraBronco
Was that even with brake maintenance mode enabled?
I don’t use brake maintenance mode. We disconnect the battery before doing any brake work or even just removing the calipers from the rotor. It’s much more reliable.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Interesting, that would be way easier than the gas pedal ignition on-off switch flipping craziness procedure lol. I thought that brake maintenance mode recalibrated the brake booster when disabled, which I could be wrong about anyway, but I suppose if the battery is unhooked for a while, when it gets reconnected, it would probably do that anyway - any idea on that subject? Or am I misremembering about the recalibration thing with brake maintenance mode??
SierraBronco
I haven’t heard of a recalibration, but that doesn’t mean anything. Many owners have had issues getting their vehicle OUT of brake maintenance mode, some needing to go as far as using Forscan to force it out.
@Ducati1098 any thoughts on this calibration theory?
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
So, Sierra, I haven't done my breaks yet, but it's something that will have to be done.. You're saying just do a battery reset on the vehicle instead of going into this break maintenance mode? That would be ideal, and I would think that would reset everything... I don't like to go through electronic maintenance modes.
SierraBronco
To be thorough as “reset” might be confusing-disconnect the battery terminals and leave them disconnected until you are completely done servicing the brakes. The computer should have no power nor ability to turn on.
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Brake maintenance mode is simply to rewind the electronic parking brake, so you can put new pads in the rear calipers. It can also be done manually.
SierraBronco
This is not accurate for the electric brake assist rigs. You need the electric boost turned off via battery disconnect or brake maintenance mode to bleed the brakes.
Ducati1098
No booster calibration as far as I know.
Maintenance mode retracts calipers, disables the rear motors and the brake booster for any type of brake maintenance needs. That’s basically it. Then when it re-initializes, it just applies full forces to the rear brakes, then backs off to the correct pad to rotor air gap.
DALOLA
Retired
Ohio 🇺🇸
Unless the Bronco EBA is different than the Maverick (I don't think it is), the EBA is off when the key is off, and has no effect on brake bleeding. Can anyone show evidence the EBA systems operate differently?
Ducati1098
Ford Bronco Are brakes same on all trims / models? IMG_0200
SierraBronco
Any thoughts on disconnecting the battery? It seems like when I used BSM the computer was still a little unhappy after returning it to normal mode. The code could be cleared but we’d still get a soft code that would resolve itself after driving for a bit.
Whereas when disconnecting the battery, I could replace and bleed all four corners without any lights or warnings.
Ducati1098
I don’t really have any opinion on it, mostly just because I’ve never tried it that way or personally had any issues with the BSM when bleeding brakes, so it’s hard to say for sure. I also rarely bleed things manually, since I have quick access to a pressure bleeder/brake flush machine.
Usually I’ll go into FDRS and activate the mode, which I’ve noticed is typically more reliable/cause less issues than doing the cheat code way with the pedal and key cycles or through forscan.
But If it seems to work better that way, I would keep doing it that way. I don’t see it causing an issue or anything.
DALOLA
Retired
Ohio 🇺🇸
Maverick service says the same thing, but it's not necessary to bleed the brakes, I've done it with no issues. There are some early year Mavericks that will not go into brake service mode (DIY), and Ford has no fix. Thus, the manual method of retracting the EPB. I've done that too, works perfectly fine.
Ducati1098
It’s for any type of hydraulic brake repair. The EBB is never necessarily “off” which is why the brake service mode exists and purposely disables the EBB. It’s not only to retract the rear pistons for repairs.
On a vehicle with vacuum brakes, I would agree that the main purpose is simply to retract the rear pistons for repairs.
But on a vehicle equipped with an EBB, it remains partially powered and ready for inputs. It can detect pedal pressure and activate the booster motor if you press the brake pedal hard enough without the key on, or even a key nearby. Brake service mode puts the whole EBB into a non-responsive state to prevent any issues.
That being said, yes there are things you can do sometimes that won’t cause an issue outside of brake service mode. You’re just not supposed to, that’s all.
Some 2.3 Bronco’s also have an issue with the DIY brake service mode procedure.
