Are all Bronco TPMS sensors the same part?
Raptor911
Raptor911
Broadlands, VA
no programming. Just install and drive and it will auto sync.
So you purchased new sensors, put them in wheels and once on vehicle it all worked? I have wheels, and new tpms sensors from Ford for the bronco. I am hoping to have tire shop put this sensor in my wheel and when I put wheel on bronconit works, I am hoping I wouldn't have to remove the time sensor and reprogram or something? Do you know if install new purchase ford factory sensors in bronco wheels that should be it, is programming if that needs done something that can be done after tpms is installed or does programming require part numbers from tpms which means id have to take them back out to program??
Bryanm
Bryanm
Bryan
Raytown Mo.
2021 Ford Bronco big bend/2022 Badlands
Mine worked fine.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Ford uses 2 different TPMS sensor frequencies (that I am aware of). For the Bronco buy the 315 MHZ.
SuperFord
2013 Ford Fusion
install the new sensors inside each wheel/tire assembly (valve stem mounted), mount them onto your Bronco and drive around. The Bronco will recognize the new sensors and self train / calibrate them.
