- First Name
- Adam
- Joined
- Aug 30, 2021
- Threads
- 554
- Messages
- 6,157
- Reaction score
- 7,049
- Location
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- Vehicle(s)
- 2018 Raptor & 2021 Bronco Outer Banks
- Your Bronco Model
- Outer Banks
The connector only needs to be rated for the actual power requirements. It's not a fuse. The fuse is what is always slightly higher rated then the load.I understand that you'd want the fuse to be higher than the load, even if using a slow-blow fuse. And that each motor should draw a max of 45A. But am I wrong to think that the connector should at least be rated higher than the fuse? I was under the impression that the fuse is there to protect the wiring (including the connections).
A 20 amp connector can handle up to 20 amps of power for example But you might have a 30 amp fuse on it.
In this case a 48amp connector is handling 45 amps of power with a 60 amp fuse.
