Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Maybe I'm a noob, but do you think I could just buy a 3.73 rear axle w/rear locker from a ranger and swap my axle out? I have the 3.73 ratio on mine, so I wouldn't have to regear.
Or am I crazy?
You're crazy. 🤪
In all seriousness, if you are looking to swap a rear axle with the locker, then search for salvaged parts. Now, not everyone needs the 4.7 gears so you can opt for a Big Bend/OBX with 4.27 gears (note: Big Bend/OBX without the rear locker are 3.73). Or look for a Black Diamond (rear locker is standard) with 4.46 gears.
Mquerin
Arcadia
Bronco base 4Dr non-sas
You're crazy. 🤪
Think I'd have to scour for a minute to find the 4.27 axle, and then I'd have to re-gear the front as well.... maybe i'll just add a locker without replacing the axle
Mquerin
Arcadia
Hi Bronco6G
This is my second post here, so hopefully this thread looks and helps as I intend.
I initially wanted to post this thread only once I was complete, but progress is going much better than expected and I thought others might benefit now rather than waiting- that and my projects always shift in priority so Im not sure when I will be able to jump back.
My goal was to add a rear electric locker but have it perform as factory as possible. Additionally, like most of my projects I want to stay as cheap as possible while also allowing me to tinker and learn along the way. So while this path may not be for everyone, it definitely is allowing me to learn as I go.
Ill break the the thread into three sections; User Interface, Electrical and Differential. At the current time of originally posting this, User Interface and Electrical are both done. While the differential install I have all the plans in place and all the materials- I just need to do the work.
Lets got into it…
User Interface:
I purchased a used “Hero” switch with rear locker optinon from eBay for about $60. The install was super easy and I would suggest using some plastic interior pry tools.
Next was to work with FORScan to get the switch turning on/off- as it will not just work once installed.
I needed to compare a VIN with rear locker only to my VIN without rear locker and determine which parameters needed to change in FORScan.
I searched for new vehicles at dealerships with rear locker only and pulled their VINs. Then I put my VIN and the other comparing vehicle VINs into this link below to pull the build info:
https://www.motorcraftservice.com/AsBuilt
I found the only difference between my VIN and a same Bronco with rear locker was as follows:
My vehicle: 703-163-03 0000 0005 04D0
Rear Locker vehicle: 703-163-03 0000 0004 04C0
So I went into FORScan, found the AWD Module Configuration (AS BUILT format) and changed the above.
My Original:
After Change:
I then loaded the change to the vehicle and check the switch functionality- the switch lit up yellow but just for a few seconds. I suspect the computer pulls power if it does not detect a load- no load because there is no locker installed right now. I still call this a WIN!
Electrical:
EDIT: Thanks to another member for the advise, buying a complete rear harness will make this process much easier and for only $114- not a bad option.
The part number of the harness is MB3Z2C011BA.
This is fairly easy now that I, unintentionally, explored all the connectors finding the simplest connector to access is all you need to access. The electrical can be done a number of different ways, again, I tried keeping this looking as factory as possible but you can also splice in your own wiring rather than running it through the below connector- this would be much easier than what I did.
If you follow the electrical harness on the driver-side outer frame-rail it will eventually begin to cross over the exhaust. Before it crosses over to toward the driveshaft there is a connector hidden on the crossmember. You can disconnect the connector and pull both ends down- they are fastened with the push-in clips that are a pain to remove.
In the connector on the frame-rail side you will see two wires that do not extend to the other connector. The ones we are interested in for the locker are Blue/Orange and Green/Brown, they are separated by two other wires.
Here is where you can choose two paths; 1- cut those Blue/Orange and Green/Brown wires and splice in your own wiring to the differential or 2- Add pins to the connector that is missing the wiring- I decided the second option.
I purchased this connector hoping that the pins would work for this application. They were definitely tight but pushing them in with a very thin screwdriver worked.
https://www.amazon.com/gp/aw/d/B07HQ5FK14?psc=1&ref=ppx_pop_mob_b_asin_title
You’ll use two of the pins on the left in the below image.
With a small screwdriver, remove the black cover on the back of the connector missing the two wires for the locker. Once the cover is removed, gently pry the blue seal out of the way too. Then run your wires through the black cover and through the blue seal. If you are color coding your wires, I kept red to mate with the Blue/Orange wire as this is COIL+ and I had black to mate with the Green/Brown wire as this is COIL-. If you keep color coding consistent here it will help you later with the differential plug. Once you have the pins from the above link crimped to the wires, then you will want to seat them into the connector. I used a very thin screwdriver to press them in- they were tight.
I then reassembled everything in reverse order- blue seal, then back cover.
I then routed the wires along the harness running to the differential. I finished the wire bundle on the passenger-side of the differential.
You will need to purchase the connector that attaches to the differential. The part number I chose is 645-685. You can find it on amazon for about $15.
I then spliced the above connector into my wire bundle that I routed to the differential.
I was then able to connect this pigtail to the e-locker solenoid and confirmed the Hero switch engaged the solenoid.
Video of solenoid engagement with Hero Switch (not sure if this will upload properly):
Differential:
The differential should be fairly simple. You can find factory Ford Ranger electric lockers, even with my 4.46 ratio ring and pinion. I bought mine for roughly $400 with ring and pinion.
Researching the axle lengths I found that I will need different length axles. You can go to Yukon and buy chromoly axles, one of which will have to be cut to length or you can find the right size from a Bronco or Ranger.
Here is the rundown of axle lengths:
Bronco With Electric Locker: Left- 30.8”, Right-32.8”
Ranger With Electric Locker: Left- 31.1”, Right- 32.8”
Bronco W/O Electric Locker: Left- 31.6”, Right- 35.7”
Ranger W/O Electric Locker: Left- 31.9”, Right- 31.9”
I was actually able to find a removed axle from a Bronco (prior owner swapped with an e-locked axle). This axle cost me roughly $600 with; axle housing, differential/pinion (don’t plan to use) and axle shafts. As you can see from the above axle lengths, you can just cut the factory axle (non locked) shafts down to the proper E-locker length- this is what I will be doing.
You will then need a Dana/Spicer differential rebuild kit for the M220 differential. This will come with both the differential carrier bearings and the pinion bearings along with shims, slinger and seals. I think this kit usually runs about $200 but I found someone selling one on eBay for roughly $100.
Before installing the locking differential you will want to buy the differential passthrough connector, you can get this directly through Ford, I found mine on eBay for $25. I had to shave it down a little to fit with the connector routed to the differential.
Then you will have to drill the axle housing to fit this connector. The below picture is a factory installed connector, I will take a picture once I have done this mod.
I have not started any of the above for the differential but when I do I will be sure to post my progress with pictures.
Total Cost Roll is roughly:
  • Hero Switch with Locker $60
  • Pins for Factory Connector $15
  • Wiring Connector $15
  • Differential Connector $25
  • Elocker with 4.46 Ring and Pinion $400
  • Used Axle Assembly $600
  • Differential Rebuild Kit $100
  • Total: $1,215
Replacement full locking differentials are around $2,500, so doing the above "Differential" section will save you about $1,300- Im good with that!
Nice modding. very cool. I was wondering why you bought the used axle and then shaved down the axle shafts if your bronco already has axle shafts that you could just shave to fit the ranger locker? I'm guessing I'm missing something. Hope I don't sound too dumb lol
wintoon
Samuel
Mexico
Just FYI I myseld did this and did not re-gear. I have a 3.73 bronco with a rear locking diff.
It works well. Unless you are climbing some real hardcore rocks you probably won't need it.
Basket2023
Pennsylvania
2023 Bronco Big Bend
Same, the extra used axle housing is the part of this excellent project and write up I didn't understand.
Also if the axle lengths can be shaved down to fit, I'm assuming there is already enough extra spline length to allow for the shave?
Hey- thanks for the question.
if you check out my section for “differential” you will see a listing of axle lengths.
The left and right axles are different between locked and open axles to make up for the internals of the locker.
You will notice that the bronco without locker has longer axles shafts than the bronco with locker. So you will be able to cut your shafts down. I actually found a video by Dana or Yukon, I can’t remember which, where they show you the process of cutting them down by hand. I’ll look for the video if that would help.
Hopefully my explanation helps. With my summer projects always taking over I plan to jump back to this in the winter so I have no other progress to offer.
Also, I got another axle housing only so I could work on this project on the side then do a bolt-on swap of the entire axle when I’m complete.
Good luck!
Just a clarification - they aren’t both longer
The axle overall length is the same, but the pumpkin sits about 1” different between the two. So one axle is about 1” longer and the other 1” shorter.
If you tried to take a set and just cut them down, you’d have one that’s fine, and one that’s possibly a bit too short even without cutting
Basket2023
Pennsylvania
Thank for your reply.
I just want to make sure we are stating accurate info here tho.
From my research I don’t believe this statement about axle lengths is true.
I also spoke directly with Yukon gear and they provided this chart, which matches my summary chart in the first page.
I’ll absolutely confirm when I have the axle torn apart this winter but Yukon Gear is a very reputable source.
Ford Bronco Adding Rear Electric Locking Differential: Factory-ish 1720404769690-l
Well I have both sitting at my garage and measured them
https://www.bronco6g.com/forum/threads/23-non-sas-bb-adding-rear-locker.67981/page-2#post-2120158
mpeugeot
People like me, who can't find a 4.27 front locker, will eventually be selling our M190 and rear gears, so it would be hard to source good condition used parts for the 4.27 or 4.46 swap.
dgorsett
colorado
F250, Mustang, Explorer
Seriously my only regret with my non Sasquatch Big Bend. If I ever feel the need for a front locker the 4.27 will complicate things. A BD with 4.46 would make it easier. And it looks like 4.27 might be dropped in '25.
mpeugeot
4.27 is done gone in 2025. According to Dana, there is a single set of M210 4.27 gears out there, but I have my doubts as to it actually existing.
I would rather regear the M210 than the M220 in my case, but I suspect that I will need to regear the M220 to 4.7 gears.
nolimits
23 Badlands
Depending where you want to go build wise, the 4.70’s are likely a better long term plan. They will play better with bigger/heavier tire and wheel combos. Also I can’t imagine scarcity of the 4.27’s improving with time.
I will say I like the performance of my 4.46’s on my Badlands, non-squatch, with the 33” BFG KO2’s. I test drove a near identical Badsquatch back to back and the 4.70’s with 35’s wasn’t as responsive.
End of the world? No but the butt dyno felt the difference. I’ve heard some say the 4.46’s are over geared for the 33’s. Maybe, but I still like it. I can’t think of once I’ve disliked having “too much” gear but plenty of times I’ve cussed when there wasn’t. Going to 35’s soon I am concerned about this as I don’t want to lose the 4.46/33 drivability.
Not sure all your specifics but I would likely prefer the 4.70’s over the 4.27’s. Cost and time being the main deterrents, as always.
mpeugeot
I have the 34.5" KO2's on it right now. I certainly can feel a large difference between the stock OBX and the KO2's, but it was only slightly diminished from the performance with the BD steelies and General Grabbers. I do feel that I would not want anything bigger or heavier with the 4.27 gears. I am pretty sure that going to 4.7 gears will tempt me to try 37's lol.
Thanks for the input, I probably will switch to the 4.7 gears.
nolimits
23 Badlands
I’ve had that devil on my shoulder for awhile now. The little bastard keeps whispering in my ear “but your tires are free, you’re upgrading wheels anyhow and getting new coil overs. Don’t waste it on 35’s!” 😈
The better devil on the other shoulder keeps shouting…..”new gears, HD steering rack, wife will really bitch about jumping in”. 😆
samf36
Sam
Acton MA
2024 Bronco Wildtrack
Hi Bronco6G
Lets got into it…
User Interface:
My Original:
After Change:
Electrical:
Differential:
  • Total: $1,215
Hey Brian, thanks for putting in all of the research and work and posting this for everyone to see!
You mentioned that you were going to cut the axles to length. I was wondering how you do it? Is there enough spline on the end for it to still properly engage?
