4A or 2H? Which is the best?
Tofudude
Chan
22 Brono Base Mansquatch
The 2022 F150 shop manual mentions a heat sensor related to the 4A tcase clutch, which can deactivate the 4A if there is too much heat buildup. I don't know if the Bronco tcase is the same, but if needing to measure heat buildup, that is potential for wear/issues and wasted energy. Maybe not likely but there is that additional complexity.
I wonder why even have 2H on 4A models if there is no difference in terms of performance and wear?
I wouldn't doubt that there is some sort of monitor for it but its still clutch based and will wear with use. I use the 4A mode if I know the trail I am on transitions from dirt and road often or if I am dealing with icy/snowy weather. For most folks using it on the daily its unnecessary and it just adding wear.
FleshTuxedo
A
PA
'22 OBX 2dr.
It’s very slight, but you can feel the difference between 2H and 4A in tight parking lot turns. It hasn't hurt anything.
Yeah, I need to get my Bronco checked out. I went to mine after this thread (it was warmed up) and put it in sport, turned out of my driveway and got binding. Then when at the gas station I turned the ignition on and it bucked forward. Something isn't right. I feel like everytime I try to do a GOAT mode (which has been only Sport so far), my Bronco does weird bucks, rolls, etc. Probably not normal?
BigGreenPony
BigGreenPony
Spencer
Ford Bronco Badlands
Maybe a transfer case or front diff issue? Ford should fix this under warrenty.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco, '25 GR86 w/Performance Pack
I feel the truck is more lively and fun in 2h, so unless its bad weather, I switch right back to it. 4A is alright, but like the rwd nature without the front kicking in because it mistakes me having fun for needing help
timhood
Tim
Several
I came across this issue by accident. I usually switch my truck to 4A for adverse conditions, such as rain, snow, or sleet. This morning I did not turn it off after a big rain and I noticed that the front end felt a lot tighter and the truck handled reasonably better (Not that the handling was terrible before). So, I now have the question, will running my truck permanently in 4A reduce my fuel economy due to all the extra drive strain? Has anyone on this forum tested this?
I'm currently getting 18-19 MPG combined on a 2.3 Badlands Sasquatch manual truck.
You aren't imagining a different driving feel in 4A vs. 2H. It's not significant, though. I stay in 2H unless weather conditions warrant 4H. You'll get a little better MPG in 2H since you aren't driving the front wheels. The nice thing about 4A is that if conditions aren't great, or change during your drive, you don't have to worry about switching to 2H to protect your driveline like you would if you used 4H. Reader's Digest version: 2H until you need 4A. Stay in 4A until you definitely don't need 4A anymore.
BigGreenPony
BigGreenPony
Spencer
Thanks everyone for the comments! Really great information from everyone on the forum. I certainly did not expect this to go to the top of the leader board when I posted this.
FordFamily4Fun
Kyle
Augusta, GA
'10 Escape, '16 Explorer, '22 Bronco 2-door
So if I read this thread correctly (did not get to all of it), 4A in my Bronco is not the same as my AWD only Explorer. Still not sure I understand why. And while they may be different, my Explorer has the same dash setting that shows how much power is going to rear and front axles/wheels. There seems to be a difference because the advanced transfer case in my Bronco can do 4A and 4H/4L while my Explorer can only do AWD? Still not sure why there should be a difference. Is 4A also using 4H in Bronco? I thought that was not advised for dry pavement.
Nc211
Washington DC
I am not a big fan of AWD, unless if the setup is fixed with a RWD bias. I don’t like torque vectoring and power swirling around the car, makes it hard for me to understand what the car is doing and how to react to it. My last car was fixed 60/40 to the rear, no torque vectoring and all of that stuff, and it was an absolute road machine in all weather conditions. It was a 2014 Mercedes E350 4-Matic sedan. But even with the basic setup, the front diff was going out at 70k miles, even with a fluid change that was not called for at 50k.
I’ve had Toyota (05’ V8 4Runner, 13” Hoghlander), Subaru (99 Outback) and my wife has a MB GLS (2020), all with the swirling AWD setup, and I just don’t like it as a driver. I prefer 2H RWD 95% of the time.
Ducati1098
Not sure what year your explorer is, but if it's a newer platform it works the exact same as the Bronco 4A. The only reason you don't have any other 4wd modes is because it's a completely different transfer case that doesn't have those options.
