4A issues. ford says this is normal?
KABQ
Aaron
Albuquerque, NM
Strizzo
Bryan
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
That's not necessarily correct, there's no way in hell the clutch pack could withstand the forces generated in low range.
This video shows a splined connection in 4H...the center splined collar slides in between the two shafts when the motor is driven all the way to the farthest point.
This was an issue Jeep has had with the wrangler 392 transfer case. Their version is awd all the time, and in 4hi/lo it just locks the clutch up all the way. What apparently happens is that if you tow an offroad trailer and spend a lot of time in 4lo, the clutch still slips sometimes, and eventually burns up compeletely resulting in no 4wd at all.
TrailRecon had this issue with his 392 and said its probably why he won't have another one.
The Ford automatic transfer case has the clutches for 4A but also locks up like a traditional part-time transfer case, so you don't have the durability issue like the Jeep version.
The 4A transfer case came out in the 2017 raptor and was supposedly the first of its kind.
To give Raptor drivers more performance and capability both on-road and off, Ford Performance engineers developed this all-new transfer case to manage the distribution of power between front and rear wheels. Key to that is clutch-based, on-demand all-wheel-drive capability for everyday driving, including all-weather mode, while also providing a mechanically locked, durable four-wheel-drive system for confidence in severe off-road driving environments.
From: Raptor's Cutting Edge Terrain Management System
twinturbo4vGT
chris
browns mills
2022 ford bronco badlands, 00 4v mustang GT twin turbo
Just dropped the bronco off this morning to have the transfer case replaced. Said I'll have it back in a few days.
