4 Simultaneous Electrical Faults - Any Ideas?
swamp2
A stretch, I know but there are lots of folks here and some Ford Techs. All of a sudden, upon starting today in my '23 Raptor, I had the following lights&warning messages:
  • Blind spot (sensor, IIRC)
  • Cross Traffic (again sensor I think)
  • Swing Gate open (it's not)
  • Passenger Airbag disabled
I think 3 of them could be rid of quicker with an "OK" button press. Odd combo, eh? Any one else have this or similar combination happen? Any ideas? Obviously off to the dealer soon. Thanks in advance.
Classic paniced computer symptoms right there.
Take a quick peek and make sure everything looks ok under the hood and under the body - no rodents, no smashed harnesses.
Reset everything by pulling the negative cable for about 5 minutes. Trickle charge overnight.
adam1991
VW GTI (2)
all that.
But don't ignore the possibility of a bad battery. Yours is probably the right-ish age for that. How long was it between build date and when you purchased it new?
Ducati1098
Can’t explain why they all happened at once. Some of them may be related to a low battery, but unlikely all of them.
You’ve got quite a few codes set:
ABS U0233:00:2B
Lost Communication With Side Obstacle Detection Control Module 'B'
ABS C0609:01:68
Park Brake Switch Circuit
ABS U3001:68:28
Control Module Improper Shutdown Performance
APIM U020C:00:0B
Lost Communication with Wireless Accessory Charging Module 'A'
APIM U0233:00:0B
APIM U0159:00:0B
Lost Communication With Parking Assist Control Module 'A'
BCM B14E7:08:0A
Right Front Enhanced Exterior Lighting System
BCM B14E5:08:0A
Left Front Enhanced Exterior Lighting System
BCM B1115:15:0A
High Mounted Stop Lamp control
IPC P160B:00:0A
Generator Mismatch with Vehicle Configuration
IPC U0233:00:0A
PDM U0233:00:0A
RCM B0052:13:8B
Passenger Seat Belt Sensor
RCM B00C5:13:8B
Passenger Seat Track Position Restraints Sensor
RCM U0154:00:8B
Lost Communication with Restraints Occupant Classification System Module 'A'
swamp2
swamp2
Ducati1098
Thanks fellas.
What do you mean exactly by this:
You didn't scan my rig did you?
I didn’t scan it, this is just information from your connected data to give you an idea.
swamp2
swamp2
Sorry, maybe dense. Don't get it. From MY connected data?
Anyway, leaving the battery disconnected for 30 min didn't clear any faults and battery (while connected - I know not very accurate) seems OK at 12.5 V via multimeter.
The only thing I can think of that might have taxed my battery is wrenching on some stuff yesterday for a couple hours with the swing gate open (maybe ran a light for that time). My short drive first thing the next morning (today) didn't exhibit any faults, but I suppose short drives aren't good to fully charge ones battery.
swamp2
swamp2
Ducati1098
Your Bronco sends information to Ford, like stored DTCs which is called connected data or a VHR (vehicle health report). I can see that information, which is how I was able to give you a list of the current DTCs set.
CalvinT
Calvin
Phoenix, AZ
Do any of those modules share a ground?
Also what modifications have you made, if any?
Anytime I have trouble with something. I often look the last place I worked on it.
MayhemMike
Mercury
You mentioned “ wrenching” …"what were you wrenching on?
Calm horse
MO
Georgia
17 f150 king ranch
12.5 may actually be low...I believe that's only about 75% charged...should be 12.6 or 12.7 ..
I thought the same thing several months ago for my f150...had 12.5 and weird shit was going on.
Had battery tested and it was going bad
Agree. Voltage readings don't mean a whole lot by themselves. A battery can show strong voltage but crap all over itself when hit with a big load, like a starter or a winch. I'd still throw it on the charger over night. It may not do anything, but it won't hurt anything either and it seems to fix all sorts of weird problems with these AGM batteries - at least for a little while, it if is indeed on the way out.
CalvinT
Calvin
Phoenix, AZ
A reading while connected should be OK with everything turned off. But I'm wondering why you only have a 75% charge unless you've been taking a lot of short trips with your lights on.
You might want to take another reading with the engine running.
Have you done anything to your battery terminals recently, or are they untouched from the time your Bronco left the factory?
