Clean electrical wiring
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
I’ve seen pictures of people’s solutions to wiring in multiple accessories and keeping it looking clean and tidy, but have not seen a dedicated thread for it. My engine compartment is a horrible birds nest of wires and I want to clean things up a bit.
What are your solutions for keeping things organized? Bus bars, circuit breakers, fuse blocks, connectors, relays, etc?
Pictures would be great! Thanks!
Wire loom and zip ties can go a long way. Friction tape can help a lot too (it's that cloth tape you see over factory harnesses and stuff)
Mine usually looks good after first install, but after tearing into it half a dozen times for things i thought of after the fact, it starts to look a mess again.
A 6 or 8 relay box can help clean up things, especially for folks that don't have upfitters.
https://www.amazon.com/Relay-Holder-Relays-Automotive-Marine/dp/B0BZS91JVS
PWillette
Parrie
Maine
I went a little over-kill on the aux switch wiring but I couldn't stand the mess plus it gives me the option to easily change aux switch postions. As mentioned above, wire looms and zip ties also help keep things tidy.
Ford Bronco Clean electrical wiring PXL_20220324_210754117.MP
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
mvilla
mvilla
San Francisco
I really like this layout. Did you just get some metal and bend it to make the bracket?
PWillette
Parrie
Maine
Yes, just a scrap piece of SS. Like I said, overkill w/ the redundant fuses but gives me options to easily change. There's also a snap on cover.
irishkpo
Kevin
Minnesota
'91 300ZX TT, '23 BRaptor, '24 2dr Yellowstone HLE
Patience to pick a good route, Wire Loom, Friction Tape, Zip ties, and Weather Pack Connectors from SPV Performance.
WheresMyBronco
Los Angeles
2023 Badlands
Dang, that's clean. Do you have a link/name of that fuse block thing you're using?
PWillette
Parrie
Maine
Thanks. I don't, was couple years ago, got it on eBay, nothing special.
WheresMyBronco
Los Angeles
2023 Badlands
Think I found it for anyone else who may be looking for it:
RED WOLF 6 Way Fuse Block Blade Fuse Box with Standard Circuit Fuses for Boat Marine Vehicle Auto RV Car Trailer Truck SUV Power Distribution Panel Waterproof Cover DC 10-32V https://a.co/d/jjcfItR
HotdogThud
mk6 gti, '21 MoarDoor
@Natai has a good setup on his truck that he might have pictures of
RideClimbNJ
NJ
23Wildtrak
I love this! I’ve been trying to figure out a clean solution and was thinking of buying this:
Ford Bronco Clean electrical wiring IMG_8276
Great seeing what others have done. Will follow and wait before I buy something.
bobbyhaynes442
Bobby
Canada
2023 Bronco
Lots of zipties are my best friend for this.
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
Deutsch 2 connectors is the direction I am starting to go in. They also work with KC lighting plugs as well. You'll need a barrel crimper and a small pick to undo or redo any connections you want. Otherwise shrink tubing, and small zip ties.
