Conoger
Thom
Llano Co. Texas
2019 KR F150, 2023 2dr Badlands EG
I have a 2025 Badlands SAS and want to add Sport mode. Looks like the trick is to get rid of ECO.
Friend has Forscan but it won't work.
Is there a build # that he needs to update to?
Anyone do a 2025 sheet yet?
Thanks!
Mg
ON my 2023 Badlands, I used forscan to just add Sport, so now I have them all, Normal, Eco, Sport, Mud, Slippery, Baja, Rock Crawl...... Maybe one I have forgot.
SasBLSven
Steen
Kearney, NE
2017 Audi Q7
She does. I removed the double honk on exit while running, but not any of the other chimes/alerts
I just received my 25 BL SAS and the double honk is disengaged. Can't from factory that way. I haven't done any of the mods yet. Are all the mods/changes wiring for the 25s? Glad I found out about the change with having to remove eco to add sport
SasBLSven
Steen
Kearney, NE
2017 Audi Q7
Might be a stupid question but any issues with making ForScan changes immediately on a 2025? Would like to add Sport and make a few changes but don’t know if I should wait until the 2025s have been out a while first.
I'm looking for a new spreadsheet for the 25s. Just received my BL SAS the other day.
je1279
Upstate NY
2025 Bronco Badlands Sasquatch
If you dont mind the screen not displaying "Rock Crawl" you can have all of the modes.
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. 1966 Cobra 427 S/C replica
Can you post the codes for this one or point me in the right direction? Everything else is done, but the reverse warning is ear splitting, and it won't shut off in Sync 4 even after changing the setting.
Here is the spreadsheet I found/used:
SkyKing
Boston, MA
Hey I think I found the setting for you to fix this:
Ford Bronco 2021+ Bronco ForScan Thread 1747598615679-x3
SkyKing
Boston, MA
That sounds a lot better. Thank you for looking that up.
Glad to help - I found that code on an F-150 Forscan forum but it's a must have with an aftermarket amp - at least for the way mine is wired with the new setup. I originally had the 2021 base 6 speaker setup that had no amp or sub. You'd have to go back to 1985 to find car stereo that sounded worse.
SierraBronco
Useful little sidenote-wifey downloaded the iOS Lite version of the Forscan app. With the screensharing I can remotely control her phone and Forscan through my iOS device. No module changes but it does have a lot of useful features with Lite.
B22-2023
Houston
Agreed, it’s a good app. I use the gauges and log all the time and its DTC read/clear feature is the best one I’ve found (very easy to read). I had a good ScanGuage (new version) ready to go in this weekend but I’m sending it back after the great past few weeks on FS Lite.
Decent support too, if you count them saying “no” to adding a requested gauge feature via email. But it was a was an intelligent exchange of 2-3 messages done inside of 48 hours though.
SierraBronco
So far I have been very impressed with the Russian customer service. Even when there wasn't a subscription cost they were always very helpful. I have no problem sending them some bucks for the extended license. Very useful program and wheeling with it has helped me get a few bronco's off the trail instead of being stuck. Before clearing all the profiles I had seven different Bronco profiles saved 🤣
B22-2023
Houston
And after digging into the app more today, I realize it has a lot of the tests, module resets - reboots - relearns of the Windows version and a lot less clunky. This can be very handy on the trails, I see now.
cmtaz
AZ
2023 Bronco
Does this disable the chimes? or just route them so the DON'T play thro the radio speaker?
thank you
je1279
Upstate NY
thank you
No this change just determines where the chimes are played through in the vehicle.
SkyKing
Boston, MA
thank you
This reroutes the chimes so they will no longer play through your newly amplified stereo speakers, but they do come through the built-in speaker in the head unit. They are still completely audible so you don't have to worry that you will no longer hear them.
JrUnderdog
Larry
Cocoa, FL
2025 Bronco Badlands Non Sas 2023 Ford F150 Rattler
I just got a new 25 Badlands. Coming from a 22 OBX. I noticed in the 25's settings on the Sync 4 that you can turn off the key outside while running Double Honk.
