2.3L - Life Expectancy?
AJKitebrder40
Adam
Charleston, SC
'23 Bronco Badlands 2D SAS, Eruption Green (Sold), '25 Toyota Tacoma TRD Off Roa
I've only had a few vehicles, some of which had engines that were known to last (22R-E, Inline 6 (Jeep)) and they did just that, along with one engine ('07 JK V6) that was a first-year production and not the best track record - that lasted 180k miles at least, but had various issue (oil leaks everywhere, lost power here and there, etc.) but it was still running.
My point is, I'm not hard on the engine of a vehicle, I'm hard on the interior (I have the washout interior for a reason) but I basically drive pretty conservatively, change the oil frequently, and that's about it. I don't go to the dealer for the 50k, 100k or whatever checkups, I have a mechanic that has Fords and pretty much knows what to do and not do without gauging me.
What is the typical life cycle of the 2.3L Ecoboost? What intervals should I really focus on far as maintenance beyond the typical oil changes, air filter changes, etc. I guess I'm 2x checking bc it's a turbo.
Lowcountry Bronco
William
South Carolina Lowcountry
Here's what Google found for maintenance schedule:
https://www.winslowford.com/2023-Ford-Bronco-Maintenance-Schedule
Think it's in the owners manual as well. Oil and filter changes are going to be subjective if you're in a dusty area and/or drive allot of stop and go. I had my oil changed at around 3k miles just because new engine break-in and currently at 7k miles now and I think it's showing half life on the oil.
As for longevity??? there's a few threads already on here but it's a modern engine, should be good for at least 100k+ but who knows on the ancillaries like the turbo, etc. If you're worried then I highly recommend getting the extended warranty from Granger, this is my first new Ford and yes, I got the extended warranty coming from a Toyota!
heavyD
Calgary, Alberta
2025 Badlands 2-Door
I've seen a lot of high mileage 2.3L on Mustang forums. It's not exactly a new engine as it's been around for a decade in it's current Ford form and dates back to older Mazda 4-cylinder architecture. It's like any modern engine these days that should last a while providing regular maintenance is performed.
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Turbos may as well be thought of as a maintenance item.. start checking its health around 100k.. but yeah.. it's a modern motor.. it should last 200k+ as long as it's taken care of and you don't thrash the piss out of it.
I do 5k oci for peace of mind.
BlueBronco
DFW
Depends on how well you maintain it and take care of it, but if done properly, it should last you 200k miles or more.
Follow the recommended service intervals in the manual. For a bit more piece of mine (and what I and many others do) change the oil every 5k miles. Some people prefer full synthetic but I just use the recommended blend on all my Fords.
And sure, the turbo is another moving part that can fail but will last if taken care of. 170k miles on my 3.5 twin turbo Ecoboost F150 and 300k miles on my 7.3 Powerstroke F250, both with original turbos.
patientB
Charlotte area
2023 Jeep Wrangler Rubicon Unlimited
If your concern is how long you can get by without a mid four figure repair bill, I’d worry more about the longevity of the automatic transmission, if you have one.
Cold_steel
Trey
Frederick, CO
this schedule is only mentioning checking diff fluid and nothing on t-case, so it looks to just be generic
Area51BS
Ron
Badlands non SAS 4dr 2.3
Clean intake valves with media blaster which you can get for about $300. Pretty easy job. Maybe at 75-100k miles.
The motor will last. It’s all the bolt on peripherals and electronics that will fail.
Lowcountry Bronco
William
Try this with your VIN:
https://www.ford.com/support/maintenance-schedule/
Looks pretty comprehensive with first t-case at 150k:
here's what happens at your 150,000 miles checkup
  • Replace engine air filter(s).
  • Change front axle fluid.
  • Change manual transmission fluid.
  • Change rear axle fluid.
  • Change transfer case fluid, if equipped.
  • Replace accessory drive belt(s) if not replaced within the last 100000 miles (160000 km).
  • Inspect brake pads, shoes, rotors, drums, brake linings, hoses and parking brake.
  • Inspect engine cooling system level, strength and hoses.
  • Inspect exhaust system and heat shields.
  • Inspect half-shaft boots.
  • Inspect rear axle and U-joints. Lubricate if equipped with grease fittings.
  • Inspect steering linkage, ball joints, suspension, tie-rod ends, drive shaft and U-joints. Lubricate if equipped with grease fittings.
  • Inspect the wheels and related components for abnormal noise, wear, looseness or drag.
  • Inspect tires and check tire pressures.
  • Perform multi-point inspection.
  • Rotate the tires, inspect tire wear and measure tread depth.
Contact your Ford dealer if you have any further questions about what's included in a service or want to make a booking.
The information contained in this chart is summarized based on vehicle mileage - see your Owner's Manual for complete scheduled maintenance information.
Also as stated, in your owners manual:
https://www.fordservicecontent.com/...d_Bronco_Owners_Manual_version_1_om_EN-US.pdf
indio22
Chicagoland, USA
A shop wanted
If your concern is how long you can get by without a mid five figure repair bill, I’d worry more about the longevity of the automatic transmission, if you have one.
A shop wanted around $2K to rebuild the auto trans in our 1999 Ford Escort. The vehicle wasn't worth repairing, so we drove it for several years with increasingly slipping shifts, until getting rid of the vehicle due to rust and other issues.
Overall I've had crummy long term service life from auto transmissions in Fords and Jeeps, maybe just bad luck on my part. On the other hand, our manual trans vehicles have been rock solid, including 230K miles on a manual Geo Storm. And that was with original clutch!
For people like me who tend to hang onto vehicles like grim death, I wouldn't want to pay for a Bronco auto trans rebuild, probably would cost a pretty penny.
timhood
Tim
Several
Mid five figure? Like $50K?! Just buy a new vehicle! šŸ’€
Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
The 2.3 has a better record than the 2.7.
Use full synthetic oil, not the ford recommended blend, because it has a turbo and the heat turns regular oil into carbon. Our 2.3 ecoboost Mustang had close to 100k miles with zero issues when my wife wrecked it.
Fordified1
Bob
Mid South Texas
I don’t think completely disassembling an overhead cam engine to blast the back of the valves is considered an easy job for most people.
Ducati1098
I wouldn’t say pulling the intake manifold would be considered completely disassembling an overhead cam engine
