Worried about my Bronco
Changman927
Russell
2007 Tundra
Has anyone experienced this? It just started 2 days ago (right after I removed the rear speakers). I left the wires hanging while I wait for replacement speakers. Other than that nothing else changed. Also ford did a software update last week for a safety recall (something about the rear facing camera).
Ford Bronco Worried about my Bronco IMG_3674
Ford Bronco Worried about my Bronco IMG_3675
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
My guess is that when you were working on the truck you had the doors open and interior lights, etc. on for a long time w/o the engine running and ran down the battery...
Charge the battery or drive it...
good luck...
RHeinz
Ric
Houston, TX
Bad battery symptoms?
You can leave the doors open all day on the Bronco and it will not run the battery down. I believe those circuits power off after 10 minutes or so. This is a great wilderness camping feature, though others here have complained about the 12 VDC outlets not remaining energized..
SWLABRONCO
SW Louisiana
Ford f150
I would check the battery voltage with a multimeter. If it's below 12v at rest then it needs to be charged. There have been alot of problems and warnings lights fixed on broncos by just simply checking and charging the battery. Vehicles today can do some crazy BS because of a low or bad battery. This maynot be your problem, but it's a good place to start. Hope you get it fix.
KABQ
Aaron
Albuquerque, NM
Did you try driving it like it recommends?
Squatch
The Bronco's instrument cluster screen will also tell you the voltage. It seems accurate enough to tell if your alternator is working or your battery drained. It would have to be on to drive it vice the center screen too.
Like OP found out, though, driving the Bronco for a bit fixes a lot of the electronic gremlins. I had some issue where I had to drive over 20-25mph for 2 miles straight and it was almost a week before I got a smooth stretch to do it.
Fordified1
Bob
Mid South Texas
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
And turn off A.S.S.. If your battery is getting weak you don’t want to be stranded at a stop light.
ASS won’t operate if the battery is low, so no worries there.
MIBronc
Wendy
Allegan
I was just about to make this same post/question! The lights do not come on when I open the doors anymore. My Bronco does Rev high around 1.4 for up to a minute, then goes down to .8... She drives fine. This has been going on for about a week.
