Draughon
Daylon
Dallas
BMW 4-Series
Did the mounting ring break off from the mirror base? These Wolfbox mirrors are much better in that regard because the base and mounting ring are molded as one piece like the OEM. It just needs BLIS fixed.
How'd you guess? lol!
Draughon
Daylon
Dallas
BMW 4-Series
Went to order and noticed it only had "heated" not "heated and BLISS" (if that's an option). I think others have reported this as well.
SeabearDivers
Midland City, AL
24 WT 2dr Carb Grey aka "The Gronco", 25 Lincoln Aviator
I just got my defective mirrors in the mail today. Though I received a full refund, I thought I would compare them to my OEM's. before throwing them away.
There doesn't seem to be much difference between the WolfBox mirror and my "objects are closer than they appear" OEM passenger side view mirror
The Wolfbox mirror (top) does cover more area on the drivers side.
Is that a digital camera we can see in the driver's side mirror? They still make those?
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
I'm pretty sure the passenger mirror comes convex from factory, so you only notice the expanded mirror on driver side. I think you end up with same results with suma, it's been talked about before in suma threads
You're basically buying a driver mirror, and getting a passenger one to match for free
No I believe our Suma mirror gave us a lot more vision
khill007
Jay
Dallas, TX
2023 2 Door
Just installed mine in 4 minutes.
No, OEM lane change lights do not work, it doesn't matter because these are so good.
Leave lane change harness plugged into its female receptor, electrical tape it to inside of mirror housing.
NO CODES!
If left unplugged, codes everywhere.
For the money, these are a no brainer.
Should have come from the factory this way. SMH?!?!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Cannot choose the BLIS version. Anyone else?
RedBeardoh
WA
2019 Ford Ranger
Earlier in the thread - wolfbox contacted all of us that had ordered. There was an issue with the BLIS on the batch they shipped out. Hopefully they are working to address it but for now it’s no longer available
Fordified1
Bob
Mid South Texas
redone17
Cold Spring, NY
Got it.
No, I didn’t read 9 pages of comments.
redone17
Cold Spring, NY
Ignorance from laziness is a choice.
Laziness and better things to do with my time are two different things. There should be an update about that in the OP.
SeabearDivers
Midland City, AL
foreWard
Ward
RVA
2022 Badlands
Mounted up the drivers side mirror over the weekend. Couple of thoughts. This is the first convex mirror I have ever used on the drivers side, and it takes a some time to get used to - similar to a rear view camera vs mirror - you eyes have to readjust/focus compared to the oem one.
Secondly, I had my fingers crossed that the BLIS system would work, since they said it was "possible the mirror would cause a system fault" but got the error immediately for the BLIS and strangely cross-traffic alert systems. I took it back off this morning and put the oem mirror back on as I am getting my windshield replaced from a crack today and need a state inspection this month and didnt want the errors to mess with either of those. Will definitely order when the corrected BLIS ones are released.
Fordified1
Bob
Mid South Texas
NO CODES!
What’s the trick to unplugging the BLIS without breaking the tiny retainer clips? I had a hell of a time.
