bobogto
Chicago
M5
I just got my defective mirrors in the mail today. Though I received a full refund, I thought I would compare them to my OEM's. before throwing them away.
There doesn't seem to be much difference between the WolfBox mirror and my "objects are closer than they appear" OEM passenger side view mirror
The Wolfbox mirror (top) does cover more area on the drivers side.
Almost the entire world uses convex mirrors in vehicles. Due to yet another stupid law the US is still falling behind. LH mirrors in the US are mandated to be flat. Manufacturers have to follow the law. These aftermarket companies do not. Problem is when a cop decides to be a jerk... You will be the one paying the ticket, not the aftermarket company that sold you the illegal device.
Beechnd
Charleston, SC
24 Bronco Wildtrak 4dr
Edit:
Sorry for causing this inconvenience, my dear friends.
For those who ordered, I managed to get another $20 gift card that can be applied both on wolfbox.com and gears.wolfbox.com, which can be added to the $15 card sent from our customer center on Wolfbox Gears.
Please kindly fill your email address and order number in the sheet below, once we confirmed, you will receive it.
Wolfbox side mirror orders
I'll update the compatibility and features here as soon as I have the info. Thank you for your patience.
Dear friends,
Please allow me to make an introduction to Wolfbox Wide-Angle Convex Side Mirrors.
Command Your View. Drive with Confidence.
Stop letting restrictive factory glass limit your situational awareness. The Wolfbox Wide-Angle Convex Side Mirrors are the ultimate visual upgrade for the 2021-2026 Ford Bronco, specifically engineered to eliminate dangerous blind spots during technical off-road maneuvers. Whether you are rock crawling or navigating dense backcountry trails, our precision optics provide the expansive field of view your rig deserves.
Key Features & Highlights:
  • 1:1 OEM Precision Fitment: This is a complete glass replacement unit, not a stick-on mirror. Specifically designed to snap directly into your Bronco factory mirror glass base for a secure, vibration-free fit that maintains your rig's rugged engineering.
  • Advanced R1200 Wide-View Optics: Engineered with specialized convex curvature to expand your peripheral vision by approximately 30%. See the entire trail—not just your fender—to spot obstacles earlier and reduce neck strain during intense off-road sessions.
  • Standard All-Weather Heating: All mirrors come standard with the heating feature. Simply connect to your Bronco's factory wiring to quickly clear frost, fog, and water droplets for crystal-clear visibility in any environment.
  • Optional Anti-Glare Blue Tint: Choose our Nano-coated blue glass upgrade to effectively filter out blinding high beams and harsh sunlight reflection without the need for complex electronic sensors.
  • Upgradeable Sequential Turn Signals: Complement your Bronco's modern lighting with an optional plug-and-play sequential turn signal upgrade. Easily tap into existing wiring for a sophisticated, flowing look that enhances safety.
  • Upgradeable Blind Spot Monitoring (BSM): Maintain your factory safety tech. Choose our BSM-compatible upgrade to ensure your blind-spot detection system continues to function perfectly while you're on the move.
  • 3-Year Limited Warranty: Wolfbox stands behind its precision optics with a 3-year limited replacement warranty, protecting against structural and workmanship defects.
Mirror features:
  • Heated
  • Heated + Blind Spot Monitoring
  • Heated + Turn Signal + Blind Spot Monitoring
Mirror color:
  • Clear (original)
  • Blue (Reduces Headlight Glare)
Master Your Surrounding Awareness:
Don't settle for limited visibility when the terrain gets tough. Snap it in, see it all. Upgrade your Ford Bronco today with Wolfbox Smart-Fit Wide-Angle Convex Mirrors and conquer the backcountry with a full-field view.
Fitment:
YearMakeModel
2021 - 2026FordBronco
Exclusive forum discount code: MIRROR15.
Better view for safer driving!
Purchase Now!
Followed the link but I’m only seeing an option for heated. Need Heated +Blind Spot Monitoring.
Fordified1
Bob
Mid South Texas
Maybe in Illinois or California . Zero cops in my state are gonna notice a convex mirror on the driver side and really give a damn as long as you can see behind you with it.
foreWard
Ward
RVA
2022 Badlands
I went the refund route as well, but they should arrive today.
I am going try the driver's side out to see if it works before tossing it out. If it works, I'm not too concerned about the legality of a part that functions better than original. But do want to keep all the functions, like BLIS.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Be aware the driver side convex mirrors are illegal in the US. There is a reason why factory RH mirror is convex and has the "objects in the mirror bla, bla" thing. Every state differentiates probably a little, but manufacturers are mandated to use flat mirrors on the LH. It's a federal law. Just be aware.
Welcome to off-road vehicle modding, my friend. Half the mods people make to their vehicles here (including mine) probably break some law or regulation in certain states. The risk averse who never drank from a garden hose or ran with scissors when they were young need not apply.
Fordified1
Bob
Mid South Texas
Draughon
Daylon
Dallas
BMW 4-Series
Previously ordered the massively overpriced SUMA mirrors and they broke with 3 minutes of installation. Luckily got a refund -
I’ll be ordering these.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
Did the mounting ring break off from the mirror base? These Wolfbox mirrors are much better in that regard because the base and mounting ring are molded as one piece like the OEM. It just needs BLIS fixed.
bobogto
Chicago
M5
Probably true, but you will be surprised. That's why I love this country. Usually the stuff that should be illegal is actually legal and the stuff that should be common sense and legal... is not. :)
I just want to point it out, because it's pretty obvious seller is either oblivious to it or not mentioning it on purpose. Also, fully aware that there is slim to none chance of someone actually stopping you for this and actually noticing it. Technically I'm riding with an illegal vehicle also, since I would not go to a dealer for a stupid belt latch relocation.
Just FYI... That's all.
Razorbak86
Northwest Arkansas
The horror! :eek:
I have driven my Bronco for five years with bead-lock rings on all 5 wheels! I can barely sleep at night knowing my intentional lawlessness, but I force myself to, just for survival! 🥴
bobogto
Chicago
M5
Highly unlikely any cop pulling you for this anywhere or even noticing it at all, but... I just though it was worth mentioning it. First off because I know about this issue from another vehicle that I have and I find it fascinatingly stupid to have a law like that. Second I feel like a lot of sellers are not very transparent about what they are selling. When I was buying my lights I was told excplisitly which ones are DOT compliant and which were not. This guy doesn't mention that what he is selling is not legal. Regardless of if we care or not about the fact.
Lifeliberty
Moonbeam👀
Columbus, OH
I'm pretty sure the passenger mirror comes convex from factory, so you only notice the expanded mirror on driver side. I think you end up with same results with suma, it's been talked about before in suma threads
You're basically buying a driver mirror, and getting a passenger one to match for free
bobogto
Chicago
M5
The horror! :eek:
Beadlock wheels are not illegal. :) You can sleep even better now. 😂
ptgptg
peter
Long Island
Not sure how to confirm you got my addition to the spread sheet.
