Wolfbox Rear Camera Mount Location - Where's Yours?
Herbie
Alex
Cleveland OH
2022 Badlands
This is a good idea. Are you able to zoom in the instance of getting a license plate behind you? Was it easy to hide the wires?
Haven't tried to zoom in on a plate, but since that is a function of the mirror, I assume so. Picture through glass is plenty clear enough. I can see people's faces through their windshields without zooming so I'm sure. Wiring was a breeze. I have wired other items through the rollbar/airbags path such as in-cab lighting so it wasn't the first time I had done it. Overall install was an hour probably.
alihenry87
Ali
Illinois
2024 Bronco
Thank you!!
TiKi-Bronco
Land O Lakes FL.
2024 Bronco
I got a suction cup mount on Amazon and stuck it to the rear window.
I just installed my Wolfbox and am trying to find the best location for the rear camera. I really like this idea. It would also make removing the top easier if the wiring was run right.
ojwouldapprove
Brandon
2024 Ford Bronco
SoloBronco
Boston, Ma
Ford Ranger
I reached out to you SoloBronco trying to get some more info on this setup mount.
I just sent you a response with links to the products I used but adding here to share with the community.
At first I purchased an EchoMaster mount that I thought was going to work.
https://www.soundoftristate.com/echomaster-phdmount
Unfortunately it did not fit the bronco spare tire carrier bolt pattern.
I bought the AGS light mount but just used the circle part.
https://agsoffroad.com/products/2021-ford-bronco-in-wheel-light-mount
I then used the EchoMaster adjustable pieces to mount the camera so I could adjust it once attached it to the AGS mount.
It works great - solid. No bouncing when driving around and the camera stays in place - doesn’t fall or need constant adjustment.
Perfect solution since I have a soft top and you cannot see anything g when the top is all the way down.
My only complaint is when it rains the camera gets wet and the view sucks. I recently tried to put a cover over the camera but it hasn’t help much.
Still 99% better than no camera and worth the money and install effort.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_9261
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_9127
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_9126
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_9260
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_9115
jclark
Jeanette
Mid-Michigan
This is working great for me.
Make sure you put heat shrink tubing over the rear camera connector. It is not waterproof.
And big thanks to WolfBox customer support who had a replacement sent out asap.
With my setup you can also have a ‘rock crawling’ mode by flipping it down with the included bracket. No need to re-mount. It swivels.
Can you share a pic of what both views look like from this position (rear facing and rock crawl use)? This mount option is intriguing, since I don't pull a trailer....
KillerPenz
North East
I just went with the same approach as some have already shown, inside the spare. Only difference is I modeled it and printed in PETG-CF, yes, I'm too cheap to spend the $100+ for what others used. Next I'll modify it again to have a spot for my air chuck.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? 20250722_172632
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? 20250722_173036
ColoradoBroncoFan
JR
CO
‘24 Bronco Heritage
I don’t have a hitch and I wanted a lower view than the backup camera.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_4467
I can adjust to show ground about 3’ behind tires.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_4473
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_4474
haynstyle
Kawika
Delaware
22 Bronco Outer Banks
How much to print me one?
KillerPenz
North East
If you want, just pay for shipping and cover the cost of filament... probably like a $3-$5 print. I'm still tweaking it slightly as it hits by like a 1/16" when putting the tire back on. But if you don't mind it being dead nuts I can probably print one this weekend. Just picked up a spool of ASA (black) for printing this as it has better properties for using in the elements.
Edit: Forgot to ask, I assume you have the Sasquatch wheels? That's what I designed this for, and it probably won't work with other wheels.
Edit #2: According to Wolfbox, the camera isn't meant to sit how I have it. Sure I can flip the view horizontally so it appears correct in the mirror, but then it records backwards. So in order to get it to record and look the same in the mirror, I need to flip the camera, therefor will need to raise it up a bit.
EasternSierra
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
Thank you all for your sharing! We're so glad to participate in your journey! Let the adventure stories be told!:rockon:
I'm wondering about keeping the outside cam lenses unscratched. Seems like they're going to get a lot of road dirt, especially in back. Cleaning that off repeatedly could permanently scratch the lens and make the cam view a lot less clear.
Do you have any product, or are you aware of any product, that could be used to cover and protect the lens?
WolfBox
Florent
LA
2021 2dr Bronco
We don't have a special cover for outside cams for now. But I suggest that you can use rain-x to repel droplet, and it shoud be of help to protect the cam.
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
I originally mounted mine on the roll bar. This worked excellent until I put my top on. Then I couldn't see more than one car length behind me. So I relocated it to the spare tire with a AGS mount. I"m going to change it, right now it's more of a semi permanent mock up done with what was handy at the time. I'm also moving it as high as possible. It just looks weird seeing cars that low.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? camera c pillar
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? Camera no spar
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? Camera clos
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? camera spar
KillerPenz
North East
I'm curious as to how well it will handle road spray when roads are wet. I'm currently in the upper left with my mount, and all the water that gets kicked up coats the lens, making it un-usable. I have a hydrophobic coating on there, so eventually is clears up. Thinking I need to 3D print some sort of shield to put below camera, but curious as your location is closer to the tire itself below, wonder if that will make any difference. Water from below is definitely the problem, not from above.
