Winch Mount for Capable Bumper w/ Flat Tow Adapters
bigred2
Jordan
bloomington, IL
2025 2D Badlands
Hello,
I have a capable bumper that is hooked up for flat towing. The adapters are welded into where the front D rings used to be. In hindsight, I should have gotten an aftermarket bumper that could accommodate a winch and the flat towing set up, but it already cost me thousands to set it up for towing and I don’t have the means to get a new bumper, and pay for flat towing installation again. Anyway, I digress. Are there any winch mounts compatible with my set up, or am I SOL? Photo attached for reference. Thanks in advance.
Ford Bronco Winch Mount for Capable Bumper w/ Flat Tow Adapters IMG_2040
Douglasjwood
Doug
Wisconsin
You would have to custom fabricate one. Looks easier than the D hooks that were there to attach on.
Bronco Naughty Pines
Jerry
Scottsdale AZ
2022 Bronco
I had a 12k rc hidden bumper winch installed, on my 22 wildtrak non modular bumper, think it would work with your tow system. I think you can see the hidden winch under the stock bumper. Hope this helps
Ford Bronco Winch Mount for Capable Bumper w/ Flat Tow Adapters 20250823_105908
Ford Bronco Winch Mount for Capable Bumper w/ Flat Tow Adapters 20250823_120141
Rivers90
Ben
Southern California
2 Door Base Sasquatch
The hidden winch kits maybe your best option. There is a hidden rear winch too, the muffler would need to be changed.
You still have options.
dgorsett
colorado
F250, Mustang, Explorer
I would recommend the RC Hidden if you have the 2.3 anyway. Installation is more challenging with the 2.7. Mine currently has an aftermarket bumper and different tow sxet up, but it should work for you.
Ford Bronco Winch Mount for Capable Bumper w/ Flat Tow Adapters 20240101_142500
Douglasjwood
Doug
Wisconsin
I loved the idea of the hidden winch. Unfortunately that would leave my winch in the elements. I don't care how sealed a winch is, after a few years of being exposed to the harsh salt roads, it would have issues. Hence, one of the primary reasons for it to be removable. Yes, it's a hassle. It's a pain to store. But at least it will last.
dgorsett
colorado
I see you're from Wisconsin you have a different reality than I. I had a Ramsey I bought in 1984 and ran as a hidden mount until the early 90's then as a bumper mount until I sold it with my Rubicon in 2021, worked every time!
Douglasjwood
Doug
Wisconsin
I very much agree! If you can install it permanently that is great. It just didn't fit my use.
