Winch battery connection, switch or Anderson
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
What are all of your preferred winch wiring methods? Anderson connector? Switch? Both? Neither?
This is how I had my Land Rover wired so I duplicated it for the Bronco. I have jump leads that connect to the battery break away and I always like having a way to isolate any add on accessories from the vehicle as needed. I will fab a bracket for some vibration resistance but its already over 90* so that will be later.
Ford Bronco Winch battery connection,  switch or Anderson 20230715_104856
Ford Bronco Winch battery connection,  switch or Anderson 20230715_104904
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
That looks nice, clean install that is multipurpose!
I just went with a rated relay back to an outfitter switch so i dont have to pop the hood.
I do see your reasoning for ability to disconnect as well as a jump point. Always wanted to put in that for jump cables, never got around to it. I now have the NOCO GB150 and it is awesome. Used it at least half a dozen times still almost a full charge. Plus moving from vehicle to vehicle is a breeze.
Felix808
SRV CA
I did the same. It also gives me a nice easy switched connection when I hook up my Viair 400P not having to undo the positive cover 🤠
