Winch or no winch???
craigels39
Craig
'21 Badlands, '10 Escape
For those of you advocating for the manual winch, could you please give some examples of what you're using? Most of the manual winches I've found max out at 3,200 lbs. Not sure I trust it to yank a Bronco out that weighs almost twice that when loaded...
Bronco21fan
Angelo
NewJersey
What's everyone's thoughts?
If your going to get into heavy off-roading it’s a must for me I just want to find some light beginner trails so I doubt I’ll need one
VictoryLights
Pittsburgh
2018 Honda Pilot
I want a winch, but Ford and the aftermarket haven’t done us any favors in this area yet. The design choices for locations of the sensors and camera from ford were short sighted in this area. The aftermarket hasn’t solved it nicely yet.
Frankie945
Frank
Louisville KY
Q50
This will get you unstuck in a emergency situation without a electric mounted winch.
NEIKO 02256A Come Along Winch | 5-Ton (10,000 Lbs) Pulling Capacity | 12Ft, 3 Hook| Heavy Duty Power Cable Puller With Dual Gears | Hand Winch Cable | Automotive Hoist Winch Puller | Recovery Gear https://www.amazon.com/dp/B000MBWCIU/ref=cm_sw_r_cp_api_i_BAJRT6QQVP8AHDHKEXBH
Felix808
SRV CA
More Power Puller. Rated as dead lift 2 & 3 ton units.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
I have the Lux package which makes it a hassle so I'll rely on my buddies on the rare occasion I might get stuck. The last time I got stuck was in 2019 in the middle of a frozen Minnesota lake heading to a buddies ice shack in deep snow and different tires would have prevented it. A winch wouldn't have helped. :)
BroncoKong Jr.
Andrew
I'm not advocating for a come-along over a winch, but if I were, I'd say get a More Power Puller
