Why do we hate Auto Start/Stop so much?
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
The inconvenience on hot days to have A/C stop working
at this point, i've never had the engine AND AC shut down due to ASS when the ambient is over 90F
are bronco's like the Mk7 golfs which had different AC programming for northern and southern climates?
adam1991
VW GTI (2)
Because it is annoying, damaging to an engine and potentially dangerous.
A bit of hyperbole there, but:
For the literal drops of fuel that it saves its just not worth it
Absolutely 100% correct.
By the way keep in mind old school or not, an engine goes into what is called "Heat Soak" when it is turned off. Coolant is stopped and the engine is deprived of any cooling and starts to increase internal temperatures. Heat is an enemy of an internal combustion engine, repeat this process hundreds/thousands of times and it will take its toll.
Facts like this matter not to the EPA theater directed by disciples of the Great Greta Herself. And the toll you mention is not theirs to worry about. Kick that can and all of its expenses down the road for someone else to deal with, it's not for the EPA's fuel economy bureacrats to worry about.
To make these systems work "correctly" vehicle Cooling Systems need to be redesigned with electric water pumps that would allow cooling to continue during "ASS" events AND A/C Compressors would need to be electric motor actuated as well.
Simple hybrids solve all of this extremely well. Toyota even spins up the engine and gets the oil to pressure before turning on spark and fuel. Frankly, every mainstream car should be a hybrid.
PrepVet
North Central WI
A bunch.
I absolutely don't understand why people hate it so much. The only thing I don't like about it is that it sounds loud when it restarts at a stop light, but assume that is because I don't have the optional hood insulation.
timhood
Tim
Several
The auto start-stop does not kick in until the engine is properly warmed up. It does not kick in if the cabin is too cold and needs to be warmed. It does not kick in if the cabin is too warm and needs to be cooled. If it engages when the cabin temperature is good but then the cabin gets too cold (in cold temperatures) or too hot (in warm temperatures), then the engine starts up again to bring the cabin back to optimal temperature. Just like a home HVAC system, it allows a few degrees of variance from the set temperature so that the system isn't constantly starting and stopping. In other words, it works exactly as you would expect it. 😄
timhood
Tim
Several
People have a lot of pre-disposed opinions about it, mainly based on conjecture and no real facts. Some people despise the idea of not being in control of everything (yet have no idea just how many components of a modern car they are not in control of. With every innovation in the auto industry, the refrain is the same: "That's just one more thing I don't need that can go wrong." Usually, the very first iterations of a new feature are not ideal, so there's a grain of truth about being an early adopter. But auto start/stop technology has been around for a long time.
The question of whether it is worth pursuing is difficult to answer without knowing the incremental cost of the upgraded components added to the purchase price of the Bronco, but the yearly savings work out to about $150 for a Bronco driven 15,000 miles per year based on average fuel prices. Of course, the exact numbers vary by individual. Those driving almost entirely highway miles won't see much savings. Those driving more city miles may see more. Likewise, if gas is particularly high in one's area. Based on those numbers, I imagine the component costs require three years to break-even before real net savings kick in.
I personally am on the fence about it as a worthwhile fuel-saving technology, given the cost, but all of the easy solutions have been implemented, and a 1 MPG difference makes a huge difference. Just how much of a difference? Assuming every vehicle had auto start/stop and saved 1 MPG, the net fuel savings would be nearly 5 billion gallons of gas per year in the U.S. alone. So there's the government's motivation. 😄 We can't complain about gas prices and foreign oil dependency and then also insist that we individually have no responsibility to achieve better fuel economy. Our Broncos aren't exactly fuel-efficient.
tock13
Tony
WA State
Personally I don’t get the point of ASS. I am averaging 20.2 mpg hand calculated after 4 tanks with it disabled and 19 mpg after 4 tanks with it on. All I need to know.
timhood
Tim
Several
See the post above yours for the math. :) There is no single technology that is going to provide massive fuel economy improvements for an internal combustion engine. Things like 8-, 9-, 10-speed transmissions, auto start/stop, etc., all add incrementally. 1 (1.2) mpg doesn't seem like a lot, but when you scale it over all vehicles in the U.S., or even just the lifetime of your specific vehicle, it makes a difference. I'm speaking just on the technical merits, not whether people subjectively like it or hate it. :)
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Because it is annoying, damaging to an engine and potentially dangerous. For the literal drops of fuel that it saves its just not worth it and by the way last I tracked this, these are OUR vehicles and we should be "allowed" to operate them how we want to and not having "ASS" is how I would prefer to operate MY vehicle. Now if the auto Mfg or the gubberement would care to compensate me (us) handsomely, I am thinking $5.00 per mile :) ) I may be inclined to let the thing work as designed. The inconvenience on hot days to have A/C stop working, the potential of the vehicle not starting (never any problems with batteries these days is there??) or shutting off in a potential hazardous situation (off roading and on a hill, etc) is short sighted. By the way keep in mind old school or not, an engine goes into what is called "Heat Soak" when it is turned off. Coolant is stopped and the engine is deprived of any cooling and starts to increase internal temperatures. Heat is an enemy of an internal combustion engine, repeat this process hundreds/thousands of times and it will take its toll. To make these systems work "correctly" vehicle Cooling Systems need to be redesigned with electric water pumps that would allow cooling to continue during "ASS" events AND A/C Compressors would need to be electric motor actuated as well. This would mitigate these issues at the cost of more complexity and larger batteries needing to be installed. 'ASS" is a crappy solution that has extremely little impact on fuel mileage and carbon emissions.
"Drops of fuel" is incorrect. You're saving quarts, if not gallons of fuel depending on how often you're stopped idling at red lights or in stop and go traffic etc. It definitely does add up. The starters in these don't go bad often at all either.
Nibroc99
Corbin
Rochester, MA, USA
moikojay
Carmel, Indiana
22 Bronco Raptor
Judging by a shocking number of the comments here, lots of folks dislike it simply to be contrarian edgelords who purposely disregard science to seem cool. The same people that are excited that the R word is 'back' and would call me a f*ggot for having purple hair.
If you don't like ASS, do something about it yourself (i.e. Eliminator harness or gods forbid lift your arm a couple inches to push that little button on your dash). You know... take advantage of that rugged American individualism you're so fond of. For the rest of the 99.9% of drivers on the road, this technology is transparent and saving incremental amounts of fuel that would otherwise be wasted.
Not saying the tech is perfect, and there are WAY better ways to save idle fuel consumption (see: Roundabouts), but it is better to have and not want than to want and not have... yes?
Dusty
Mentone, CA
70, 71 & '21 Broncos
I guess I must be a contrarian edgelord because I don't like the auto-start-stop LOL. If they would just make your last selection persistent (leave it on if you left it on, leave it off if you left it off, next time you start the car), we would all get along fine.
moikojay
Carmel, Indiana
22 Bronco Raptor
I guess I just don't see the huge inconvenience of pushing the button when I don't want ASS to kick in. I already have to double click my Raptor button (which actually does save ASS setting), press the OK button twice to clear the Offroad Use Only and Seatbelt warnings, and shift the vehicle into D every time I get in.
Would it be cool if I didn't have to do those things? Sure. Does it diminish my enjoyment of the truck literally at all? Nah, I have thicker skin than that. It also feels like a 'preflight check' sort of ritual.
Exactly.
I don't care that ASS exists - for people who want to use it, great. But why doesn't it take into account ~my~ preference, for ~my~ vehicle?
(I did do something about it, I installed ProCal. Then they patched it out of ProCal after the fact...)
I love how people can say in one sentence "Accept me because of my hair color" but in the next breath condemn someone else because they don't want to push extra buttons...
