Don't like auto start stop
Lowcountry Bronco
William
South Carolina Lowcountry
I don’t know about gas mileage difference. But using forscan and disabling has made me not think about every again.
This will be my plan once delivered, go thru and fix the speakers, add the modes, get rid of ASS and the double honk. No need for anyone with a laptop not to do this for minimal cost.
Lèòn
Jersey
USAGUY
Ny
. I did hate it at first. Doesn't bother me at all now.
Sonny
Sonny
2022 Bronco Badlands
Two minutes and forscan disabled mine. Another 30 seconds on the HVAC module disabled the light on the button.
Fold
Bronco, Kia EV6, Mach E, Miata
Maybe I am weird, but these have never really bothered me. I actually like it in combo with the MT because if you stall, all you need to do is push the clutch to restart.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
The only thing I've discovered I don't really like about my Bronco...the automatic engine shutdown feature. It's really not a dislike, I guess. It just generally annoys me because I feel like an engine shutting down for a minute while I'm at a stop light doesn't do much. For it to really matter every car would need this feature, but of course that will never happen. Someone tell me, how much of a difference does leaving this feature on really make?
Engineering Explained did a great video on the fuel savings. Not on the impact of the engine, mid you. A typical engine with the Auto Start/Stop feature saves net-fuel burned as long as the engine is off for more than 7 seconds.
Shazamalingo
West
2022 OBX SAS
It has a pretty significant impact on your gas mileage. If you want to see how much, do a comparison. You can see your MPG drop as you idle.
AZ_Liberty
2007 Expedition
Auto restart on stall and AS/S are separate features. If you have AS/S off, and stall, punching the clutch should still restart.
Although, there is very little reason to bother to turn it off in the manual. I only turn it off when I am at the drive-up ATM.
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
I don't mind it at all - and with gas well over $6 a gallon (close to $7)- if it helps stretch my gas mileage a bit, I'm ok with that.
22OBX
Bryan
Hartford, AL
It has a pretty significant impact on your gas mileage. If you want to see how much, do a comparison. You can see your MPOG drop as you idle.
Yea 0 mpg at idle. I’m getting more used to it and don’t disable it as much as I did at first. Debated turning it off but I do know it saves fuel if you are doing a lot of stop and go although it promotes rolling through stop signs 😂
TXAG96
Tyler, Texas
'20 Bullitt, '01 Boxster, '87 TBird Turbo Coupe
on 2019 F-150 you can jumper 2 wires on the A.S.S wiring harness and disable it. Can the same not be done on this one???
AKBronc49
Russ
Anchorage, Alaska
At almost a year it's pretty much second nature to turn it off when I put it in gear. Sometimes I'll forget, get to a light and yell God damnit and turn it off lmao mostly after driving my other vehicles as my Bronco is the only thing I own with it.
I should get the eliminator...
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
It does not do anything in the grand scheme of things other than annoy the owner. I installed an autostartstopeliminator. Took about 10 minutes. Money well spent.
I did the same thing. Very glad I did.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
I’m not much of a computer guy, so I was nervous to mess with the forscan stuff, but it was really easy with all the help from this board. I got rid of all kinds of annoying warnings along with the a.s.s.
Lèòn
Jersey
Monkey wrench time: doesn’t A.S.S. wear out the starter? I get those will go anyway, but why acceleration its demise?
