Which automatic Tire deflator should I get?
telenerd
Laramie
Subaru
I have the 4 tire morreflate system to air up and down. I tried Stauns and other brands and they are easy to do but take longer to air down and not very accurate. With my system I just connect all 4 and air down. You get pretty fast at winding up the hoses when you’re done and Morreflate replaces any parts or compressors at no charge or questions asked. I believe they have lifetime warranty now on all their stuff.
bf4445
Britt
Oregon
2007LarietCC4x4, 2018FocusTit, 2016Jeep reneTH
Even using these for years. They‘re knockoffs of the Staun I think but there is nothing cheap about them.
Tire Deflator, 10-30 PSI Adjustable Automatic Tire Deflator Kit, Air Down Tools Offroad Accessories for Jeep, Car, Truck, Motorcycle, and ATV Tires (4 Pack with Storage Bag) https://a.co/d/bGeceAn
good idea but will never buy anything from bezo one of the biggest crooks the world has ever seen
Combustion_King
Derek
MA
Yes
I have the Staun ones and they are nice. pricey but nice. No issues, i like em.
JF Bronc
Atlanta
Ford Bronco
Apex Design 40 psi to 18psi in about 10 seconds.
@Discount Tire installed for me.
@Dugout, when you replaced a Schrader valve with an Apex valve, what do you need for airing up? It hasn’t been clear to me on what adapter you need on a standard compressor hose to work with Apex. I assume you need a unique chuck that you have to swap out on your air hose to work with airing up an Apex valve. If it is a unique chuck, are there any issues that you know of with incompatibility? Thanks.
Dugout
Joel
ETX
24 Bronco
I use EZ FLATE air hose and chucks. It’s the only chuck I have ever used. I got a single hose when I bought the 4 tire kit.
I’ve had zero issue with the valve. I have the XL length with OEM BD SAS rims and it’s still tight for the release valve and air chuck. That would be my only complaint, but that’s a rim issue not valve issue. I can air down in less than 5 minutes and be on the trail. I have loved them. To me worth the investment if your off-road 1-2 a month.
@SierraBronco @Bigmoose
What chucks do you guys use? Any issues?
SierraBronco
I tried the apex chuck as it is high flow, but screwing it on/off proved to be problematic with the beadlocks getting in the way. Ended up getting a locknflate and it is much better.
LT. DAN ICE CREAM!!!
Philadelphia, PA
2021 Badlands
Buy once, cry once. Stauns for my rides through Wharton State Forest in NJ.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
I use an Apex screw on chuck. I found most push on chucks leak. Apex makes a push on but i have not tried it yet.
Easy-v
U S A
BadSquatch
The Stauns are quality, but are not good if you need to change your pressure at all . Another drawback to the Stauns is there isn’t a good way to assess if the pressure you set on them changes….unless you use a sharpie or some other mark….
I went with these after using the Stauns for a bit…
https://over-sand.com/
Still have the Stauns, but the. Over sands are my go to as they have a built in dial. Not as bomb proof as the Stauns, but far more practical…. If you off-road in more than one environment….go from dune flat (10psi) and then some other day need traditional off road/18 or 25 psi
Also +1 for the quick disonnects
Scott R Nelson
Meridian, ID
Go with a 4-way inflator/deflator system if you can. There is a company in Utah that makes one for a decent price - can't remember their name. I built my own for $150.
The biggest advantage is that all four tires have the same pressure when you're done going up or down in pressure. I use a timer to get the pressure that I want, after a couple of times figuring out how long it takes to get where I want to be. Three minutes to drop from 39 to 20, ten minutes to go back up again with my Smittybilt pump.
Ford Bronco Which automatic Tire deflator should I get? Qy2mYdK
Easy-v
U S A
BadSquatch
Sometimes thats too mich crap to carry
especially if you offroad somewhere that has airing up stations nearby
Scott R Nelson
Meridian, ID
I have never seen an airing up station anywhere in Utah, Idaho, or California. Where do you find such a thing?
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
Fast?
That's been my problem. Finding a solution that will clear the beadlock ring. Ford sure put those valves close. It's a PITA to even get my air cuck to stay on those, much less a deflator.
So far, I've just been using those painfully slow automatic deflators and making a sammich or something while I air my 37's down.
SierraBronco
Fast?
Fast…?
And el em aye oh yeah. Those deflators take so effin long it’s hilarious. Then homies with their four hose systems. After the second time using them they just throw it in the back. Gets all tangled up. Adds another five minutes just to get their knots undone 🤣
