Where & How to Mount Winch Cut-Off Switch
Felix808
SRV CA
I have a cutout solenoid mounted there:
I have mine mounted similarly but stayed away from any chance of rubbing through the a/c line with a simple fab'd backet . Aux switch wired for control voltage 🤠
Ford Bronco Where & How to Mount Winch Cut-Off Switch 1784157801014-33
KreeHBronco
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I really appreciate all the help and good ideas! I am pretty handy for being a noob, but my access to any kind of metal fab is extremely limited. I thought about drilling some holes near the battery's chassis ground lug in the flat area and using rivnuts to attach the switch, but to make this work I really need to move the chassis ground lug and I am too worried about causing an electrical grounding problem. Next up, has been searching for an aftermarket bolt-on bracket, that mounts somewhere near the battery in the engine compartment. I have looked at Bracket Bros (mounts over battery)., Genesis (mounts over fuse box), and finally SDHQ (mounts on the side above fuse box but doesn't cover it. Below are images and websites in case any of you are interested.
I ended up buying the SDHQ and it being shipped. Once I get it and install it with the switch, wire up the winch, I will take pictures. Wish me luck!
https://thebracketbros.com/products...60711&pr_ref_pid=8641834025159&pr_seq=uniform
Ford Bronco Where & How to Mount Winch Cut-Off Switch 1784160220485-ms
https://www.genesisoffroad.com/products/accessory-mounting-bracket-for-the-ford-bronco-6th-gen
Ford Bronco Where & How to Mount Winch Cut-Off Switch 1784160254863-26
https://sdhqoffroad.com/products/21...bronco+power+mod&_psid=31859f381&_ss=e&_v=1.0
Ford Bronco Where & How to Mount Winch Cut-Off Switch 1784160410384-ga
