Wheel locks
rii_505
Ricardo
PR
Hi!
I bought a used bronco badlands however the previous owner does not have the wheel lock for the lug nuts. Is there any way I could remove the wheel locks without destroying my rims.
thanks
Ford Bronco Wheel locks IMG_6371
PSUTE
Western Maryland
Sierra
Cannot believe that previous owner does not have the key...
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
You can buy replacement locking lug nut keys or as previously recommended the dealer should have a master set.
Doc TOC
Los Angeles
Expedition Max, Fusion Hybrid, BMW 5 Series, HD Road King
They’re useless
Like he said ... Forgot to give the tech at Goodyear Tires the key. He torqued them off with his air gun. Had them toss 'em and put regular lug nuts on. Never looked back. ... Try your local tire dealer. One way or another, I a sure they will get them off.
JerryC
Memphis
2022 Bronco
Have you looked around the vehicle? He or a tech put it somewhere and forgot.
First place to start is with the lug wrench. It may be wrapped in something like a rag so it didn't bounce around.
JerryC
Memphis
2022 Bronco
I had a set of tires put on my 4Runner. As we were driving home I had this feeling that I should check that they put my lug key back with lug wrench.
Pulled over and looked, nope. Had to go back to the tire store and get it.
I could easily see somebody driving away from a tire place and not thinking about the key.
rii_505
rii_505
Ricardo
PR
Hi! Unfortunately the dealership did not offer me that solution but i will try a different dealership. I thought I could just buy a new OEM set but I’m not sure if the lock will be the same.
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
Most dealers should have a master kit. Give them a call before heading down. Swap out the locks for regular lug nuts or they can order you a new key once matched up.
TRACKTOY
ANDRÉ
ST-AUGUSTIN-DE-DESMAURES Qc. CANADA
F150 LARIAT CREW C. 3.5L ÉCO 2022+ BRONCO BL.2023
Good morning
I don't trust any dealer. My locks are advancedwheels lock, so I remove them before going to the dealership. I believe we are responsible for what happens to us. So I believe in myself to take care of my business not at the dealerships or the mechanic. sorry for you but if not ADVANCESWHEELS LOCK with a box and a 30 second hammer They are removed. ask you tube to check the method.
tracktoy
adxl
Atlanta
Sportrac Boxster
Same thing happened to me at the local tire dealer with my Porsche. It makes me think that you need check to make sure they put all the lug bolts back on lol.
Seems like a lot of low end mechanics are lazy and sloppy. My suggestion is you find one whose committed to doing good work and stick with them or take things into you own hands.
JerryC
Memphis
2022 Bronco
I did and made sure the lock fit the lugs. Also checked the lug nut torque.
Blue Hen
Delaware
Remember when using wheel lock key. No impact drivers only hand tools. We use our master kit when vehicles have wheel locks. Some customers have no idea where they store the key.
