Transmission skid plate installed
bkfit
bkfit
BK
Spaceship
Yeah I noticed that after Install. Hopefully my 4inch lift will help with clearance, possibly fab a cover too…
Needs coverage over the transmission cross braces. They seem to get hit a lot. The LOD covers all of it and works with the factory skid plates
Might be ok, Any rocks logs will contact trans skid due to it hanging down more then trans brace brk. I should be fine.
Ford Bronco Transmission skid plate installed IMG_1590
contented
Karl
Central Fl
BMW M2 Competition
I like how this has stiffeners welded in. My Mabett trans skid does not.
They charge a bit extra for the stiffeners, but not too much and I thought it was worth it.
Jakes22
Jake
North Texas
2022 Bronco, 2022 Silverado ZR2, 2005 Sierra 1500H
There might be a reason Ford offers skids for everything under the Bronco EXCEPT the transmission. I doubt it’s because the Ford engineers forgot about the transmission.
Doesn't the Raptor Bronco have a transmission skid? Same transmission isn't it?
Midnight_Blue
Jeremiah
Los Angeles
Doesn't the Raptor Bronco have a transmission skid? Same transmission isn't?
Yes and yes, although I’m not sure if there are other important differences between the Bronco Raptor and the other Bronco trims. I’ll let others gamble with their warranty to find out. We do know that before the Bronco Raptor existed, Ford tested the hell out of the other Bronco trims and their engineers decided not to put a metal plate there, even on the Badlands trim.
Fordified1
Bob
Mid South Texas
lol they also decided to run the Hoss 2.0 steering rack, those geniuses that they are. Sorry, I don’t take much stock in engineers when bean counters actually make the decisions.
Midnight_Blue
Jeremiah
Los Angeles
I’ve yet to see a stock setup have issues with the steering rack.
Talon2006
Houston
F-150l, 91 Eagle Talo n
This, I found that that area really has not been hit on mine. I do have a design for little covers for those.... I just never really finished it.
bkfit
bkfit
BK
Spaceship
Nice! Better angle for those that might be interested.
Ford Bronco Transmission skid plate installed IMG_1961
userdude
Denton, TX
2023 2dr Badsquatch
I’m pretty sure it’s called heat dissipation. You probably don’t want your tranny overheating on the way to Starbucks.
Did this come from one of the engineers? I'd argue they left it off to save weight, as it seems like they did elsewhere (it is "way up there"). I can't prove that, of course, but I don't state it like it's fact.
Multiple reports of people hitting their trans pan off roading (including an infamous one on Mater's YT channel). Number of times I've seen anyone complain of trans heat issues using a plate on this forum: 0
Not saying you don't have a point (my SFR plate has big holes for that). I just don't think it's a given this is a true assertion, just as what I suspect is really just speculation.
Fordified1
Bob
Mid South Texas
Multiple reports of people hitting their trans pan off roading (including an infamous one on Mater's YT channel). Number of times I've seen anyone complain of trans heat issues on this forum: 0
I agree. Maybe if I towed it would be a legitimate concern, and I would add a transmission cooler. Automatic transmissions are not air-cooled they are fluid cooled.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Its called "Value Engineering", least amount = best "Value" to the stock holders.
Callelk
Larry
Idaho
Callelk
Larry
Idaho
It all comes down to weight as you mentioned. If you ordered a BD with the slide-out tailgate, you can't order the SAS package. But with the HE you get SAS and the slide out tailgate but you can't get the "bash plates". However, the the "bash plates" come standard in the BD with SAS.
For legal reasons the mfg's have to abide by CFR 49, part 567. Does that mean you can change the Territory tires to Baja AT's and add 662# more weight to your Bronco. Maybe...........
Midnight_Blue
Jeremiah
Los Angeles
All the other skid plates add weight, too. The transmission plate is not unique in that regard.
