Transmission fill tool
NMOBX
Paul
New Mexico
2022 Ford Bronco Outer Banks
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
Use your tube bender with 5/16 or 3/8 tube and bend to the minimum radius. It will work fine. There is plenty of room under the Bronco to properly position it.
NMOBX
Paul
New Mexico
Thanks, I appreciate the feedback!
B22-2023
Houston
The Motive kit has 15% off now, I’d get one if I wasn’t already set up for this. And it’s almost half price of just the bent tube that Freedom somebody are selling!
NMOBX
Paul
New Mexico
It’s pretty ridiculous that something so simple would cost so much!
Valhalla War Machine
MikieG
Overland
88 Pontiac Fiero GT, 2022 Ford Bronco
I just bought my Bronco at 33k miles. How Do I find out if the 10spd has been serviced?
What intervals does Ford want it done at?
astogs1
Al
SW Chicago Suburbs
2024 Bronco
I was reading the service interval for the trans on my ‘24 Badlands 2.7 is 150k, hard to believe, can someone confirm?
Ducati1098
Maybe this is an obvious question but what (real world) cleaning do people do with these?
I'm not sure what you mean by cleaning?
SWLABRONCO
SW Louisiana
Ford f150
I bought this rig on Amazon. It comes with several adapters. It will suck the old fluid out and blow the new fluid in. Works better than the old girlfriend.:crackup: It really does do a good job and helps reduce most of the mess when dropping the transmission pan.
Ford Bronco Transmission fill tool Screenshot_20250826_102447_Chrom
Techun
Pa
BD, 2.7, MIC, 4dr
I guess maybe more for the mityvac ones that aren't just for filling. Like if it has used oil in it, then ATF, then old gear oil, then new motor oil, etc.
How much cleaning are people doing between fluids...I'm guessing none because that sounds like a pita
Ducati1098
No idea. I have multiple things for separate uses. So none of my clean fluids are mixed with dirty fluids
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
They will say first service after warranty is over (as everyone does). Do it every 30K minimum, I only use Amsoil ATF and never look back
