- jim
- Apr 9, 2025
- 6
- 166
- 210
- North Dakota
- 22 bronco
- Base
Thanks. I have the part time case. I'll track down a crush washer and sealant for the diff.s
Nothing to worry about on the manual transmission. It has a built-in rubber seal on the plugs which should be perfectly reusable if not damaged.
4A transfer case plug can be reused with new PTFE sealant.
But the part time transfer case uses crush washers, which should be replaced, but can realistically likely be reused without issue also. To each their own there.
