Magnetic Differential Drain Plug
Batson35
Ohio
Black Diamond 4Dr & Badlands @ Dr
Are the magnetic differential drain plugs of the front and rear diff and the transfer case plug interchangeable i.e. all the same part number etc
Thank you all in advance
Ducati1098
Yes. They're all 1/2"-14 NPT
anomdeplume
Tampa, Florida
2023 Bronco Base, 2023 Bronco Sport Badlands
Unless you have the standard transfer case. The “non advanced” 4wd transfer case uses different plug bolts with washers. At least from the factory. They may be interchangeable but they are not the same.
Ducati1098
Yes, those are completely different and won’t fit or interchange with the standard NPT plugs
