Torsion Bar Question
RideClimbNJ
NJ
23Wildtrak
I have a Wildtrak too. How would you say that upfitter sway bar disco has held up? Any issues?
I’ve only had it a month or so. I tested it on some ramps to make sure I wired it correctly and then had one full day on the trails. Worked perfectly, but that was just one day out there. Since it’s the oem part I’d assume it has the same issues/lifespan as the one people have in their Badlands.
GI_Jo_Nathan
Jonathan
Does anyone offer a lower rate (more twisty) regular sway bar, something that would fit in place of the stock sway bar, maybe even use the same links? It seems that's basically what these other sway bars are doing - providing a lower effective rate via twist/leverage hence allowing more articulation.
I just took off my front bar, and added the stock rear bar.
GI_Jo_Nathan
Jonathan
Be careful though, if you only run a rear sway bar, it can change the under/over steer characteristics of a vehicle.
I removed the front sway bar from my CJ-7 no issues. I'd remove it from my Bronco as well, but the vehicle sees a lot of street driving by family members, so it needs good road manners.
Agreed. Definitely makes it way more fun to drive on the road.
SierraBronco
I’m pretty happy with rear only. Tried factory front and rear, BOSS links on front, front delete, front and rear delete, and now rear Rockjock only. Rear RJ only seems the best so far though it is getting beat up more than the factory rear did due to triangulated four link
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Yeah, seeing that video, not sure how long that poor rear RJ is gonna last on your setup... :whistle:
SierraBronco
Right? Probably gonna ditch the ubolts and weld the brackets to a better spot on the axle.
dgorsett
colorado
F250, Mustang, Explorer
"Tried factory front and rear, BOSS links on front, " So were either or both of these before the four link? I might go with either of these. How did you think either affected articulation? And is a BOSS link a Walker link?
SierraBronco
Did the Boss (Walker) Links before triangulated four link. Gained I think an inch of articulation. I might be wrong on that. I know they're just a little short of what you get from the electronic swaybar disconnect. But you will get a noticeable improvement on ride quality, particularly over small bumps and what not around town. I don’t think they gained anything with the four link as the factory shocks became the limiting factor.
dgorsett
colorado
Thanks. Any improvement with the front and rear together?
SierraBronco
That’s how ours came stock, so we can only provide feedback on mods or deletes. The factory rear definitely got beat up less that the antirock with the four link. But we never tried it with the RK coilovers
dgorsett
colorado
Mine only has the front. Some folks say having the rear too holds the front down off road. I'm trying to see if it's really true.
SierraBronco
Earlier in this thread a video was posted showing that rear only improved overall articulation. It was pretty informative
TopRamenGod
2023 Bronco Wildtrak
Any issues with the Hoss 3.0/Fox Shocks setup? Or is your Wildtrak from the 1st half of the MY2023? (I think the switchover from BIlstein to Fox happened in the second half of the MY2023 WildTrak production, right?)
If no issues/adjustments necessary, I was pretty much going to follow @StinkBug's video to a T, probably put the disco on AUX4.
RideClimbNJ
NJ
23Wildtrak
I have a newer 23 with the Fox shocks - goes on just like in the video. Nothing different.
grannas211
grannas211
Brandon
Pittsburgh, Pennsylvania
'23 Bronco Wildtrak, '97 Camaro SS
@Carli-Dan
I just went ahead and placed the order for your torsion bar. I wanted it shipped to a different address than my billing. I accidentally forgot to change that. Is there any way you could help with that? Thanks.
