Stroppe Edition Rear Sway Bar Question
23OBX2.7
AB Canada
2023 Bronco
I can get Ford OE rear sway assembly from recycler for $100 but I think I'm going to get Hellwig instead ...my OBX will never see more than a rocky holled road because I have KTM for off roading...need to reduce lean and dive as much as possible.
ThunderFlash
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
For now I would just add the oem rear bar and see what you think. Reevaluate the front bar after you have tested things out a bit.
I have an oem rear bar I was going to put on in the next few weeks. I only have about 1” of lift on 6100 bilsteins. Not sure about the end links for 2” of lift but I suspect they will be fine. I will know more after I mount my bar.
How'd this turn out for you? I'm still on the fence about it. After putting some more off road miles on, I'm liking the set up more as it is, sans sway bar. Then on the other hand, it's not a HUGE amount of money and might even be better. But I won't KNOW until I try it.
87-Z28
Andy
BMW
I have not yet done this. I am reducing spring rates on my coilovers so I think this will be a welcome improvement. My new new goal is to get this done over the holidays. Maybe. Some additional info in this thread.
https://www.bronco6g.com/forum/thre...ngs-to-effect-ride-height.122330/post-2643653
GI_Jo_Nathan
Jonathan
Been running mine with the front disconnected, and added a factory rear sway bar on and off road for a long time. I prefer it.
