Rear sway bar
tdiddy
Tommy
Illinois
2010 Ford F150, 2012 Ford Focus
Just received my Belltech and installing next weekend . Which mounting did you use, the oem or sport hole?
I actually have mine set to the tow/haul setting. I have a lot of added weight.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Can someone post a pick of ground clearance? Is it different per setting?
redone17
Cold Spring, NY
Bump for ground clearance pics.
bravely
Brad
3490 s leonard rd, new palestine in 46163
1973 Mustang
I just added the factory parts to my ‘22 two door Sasquatch, bought from a fellow B6Ger who removed them from a '22 four door Sasquatch and it makes a big difference to me on the short wheelbase, especially the brake dive aspect. You’ll have to get the rear suspension in full droop, especially on a two door, to get it snaked in there up tight with the gas tank.
"full droop"? What did you have to do?
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
I went ahead and ordered the OEM rear sway bar from Levittown Ford.
The rear way bar combined with my FP Bilstein lift and a LSD will make my 2 door quite lively on the street and high speed dirt driving.
0ne
Nate
CO
Flex
Lift up the rear of the Bronco by the frame until the tires come off the ground allowing the rear suspension to naturally drop down completely.
Aonarch
Jack Hoff
MT
Did you order NB3Z-5486-A retainers, or do they actually come with the bar?
I read that they come with the bar, so I skipped them.
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
Was anyone able to successfully install RSB on theirs?? I’m stuck because there’s a gas tank in the way and I can’t find a way to get past it
0ne
Nate
CO
Flex
Replying for continuity…
The suspension has to be fully drooped out and the vehicle on a lift so you have full maneuverability of the bar.
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
Your butt is telling you to slow down in the turns. lol. I went from an M3 to my Raptor I thought I was going to die. lol. It took some time to learn how to hustle a 6000lb soft suspension top heavy truck with 35" tires. Now I am comfortable with it and confident in it's limits.
Older post but EXACTLY this!! Purchased my 2018 Raptor new from St. Louis MO dealer, (not paying West Coast ADMs), driving home cross-country coming down the I70 near Vail CO, definite pucker moments when I thought truck’s rear end was going to step out when hitting bumpy, wet curves at freeway speeds. Installed a Hellwig rear anti-sway bar and it really settled the rear end down. Drove much more planted/solid after that. Will be considering for Bronco as well.
  • Like
Reactions: 0ne
Broncoco
Half Moon bay
2022 Bronco
Any torque specs for the OEM rear sway?
