Tailgate Reinforcement for 37's
STYLZ
James
2023 Ford Bronco Outbanks Sasquatch (4-door)
I am going to be doing a 3'' lift soon and while it's in the shop, I was thinking it would be good time to get the tailgate reinforcement done for when I upgrade to 37's in a couple months. I have a OBX SAS, with stock rear bumper. Not sure if I would need a spare tire relocation at the same time for when I get the 37s? I am trying to more or less future proof for that.
I've seen a few different one's out there and wanted to get peoples feedback and recommendations.
Oldhippie
Barry
Santa Cruz, Calif.
I don’t think there much difference in function between the metal plates…the hinge replacements are stronger…I like the Raptor setup for value…but I am cheap and went with allied…may never actually hang a 37” spare back there…
Hammer built, Turn Offroad and Raptor hinges seem to be the most common talked about when dealing with 37+. There are a slew of other reinforcement brackets out there though.
Ninjak
Miami
I run the DV8 Spare tire guard and accessory, along with the TOR Camera/Tire mount. Love my setup. I needed to use the TOR mount because my OEM mount was damaged when I had it off the RIG.
The DV8 is a great setup, and you can even lock the guard around the spare if needed.
Ford Bronco Tailgate Reinforcement for 37's 1715477929021-69
Felix808
SRV CA
You would be better off getting a bumper / tire carrier system that gets all that weight off the swing gate while moving the tire up some. $.02 🤠
daveness
San Diego CA
2021 4dr Badsquatch, 2018 Sprinter 4x4, 1903 Cad
Turn Offroad has a great tailgate replacement really. The factory tailgate bolts to the Turn Offroad switch gate. It's built strong. It also moves your tire mount up for 37" tires but you still need to extend the 3rd tail light. I'd also look at bumper mount because then you don't have cantilevered weight on the body side. But I believe bumper mount is a whole other cost level.
Baja Bronco
2Sun AZ
I run Hammer Built, no complaints. IMO, best one out there. If you’re going to run 37s, get a brace.
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
I went with Turn Offroad route. Watching their video sealed the deal. The adjustable spare tire mount helps with tucking off set wheels closer to tailgate. As you know when shopping for new tires even 35's the weight increase is minimum 10 to 12 pounds more than the Territory MT.
TOR’s completely replaces the hinges and is a different hinge mechanism - the carrier bolts right to a plate on the new hinge and the tailgate bolts up on the other side of the plate; it’s a bit more than just a brace; not quite the bumper mount option but a close second. None of the weight is carried by the tailgate, but the weight is still carried by the right side frame mount (where the stock hinge bolts up).
Raptor is a beefier hinge (that also supplies some mounting points), but the carrier still bolts to the tailgate. Mabett has knockoff hinges of this style
Braces just reinforce the existing hinges by providing cross bracing. Hammerbuilt braces are this type, and there are many others. Still uses the OEM hinges and carrier bolts onto the tailgate.
And then the bumper mounts move the carrier to a swing arm on the bumper. So the tailgate no longer sees any of the weight and the weight is moved to wherever the bumper mount has it carried.
The stock setup is rated for 133lbs, so it’s no slouch; which is a good reason why many people just go with a cross brace setup.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Another vote for @Turn Offroad - I have their tailgate reinforcement bracket for my 35’s and it’s great. I recently upgraded my tires and they are significantly heavier than the OEM tires - no issues. This is very well built! They sell an add-on piece for larger tires as well, so everything should work for your needs.
Old picture, before the new tires:
Ford Bronco Tailgate Reinforcement for 37's IMG_5052
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
2022 Bronco Badlands Sasquatch
Another suggestion for Turn Offroad it is solid. Love that you can raise the spare height which really helps with departure angle running 37s
Ford Bronco Tailgate Reinforcement for 37's IMG_4907
Ford Bronco Tailgate Reinforcement for 37's IMG_3637
Ford Bronco Tailgate Reinforcement for 37's IMG_4861
Ford Bronco Tailgate Reinforcement for 37's IMG_4862
Ford Bronco Tailgate Reinforcement for 37's IMG_3701
Mjasi3
Chicago
