Sync update woes, OASIS / FDRS
hec1
Hector
2022 F150 37PP Raptor 2024 Shelter Green Raptor
Did anyone lose their shortcuts on iOS? I had automations for locking the doors, unlocking the doors, seeing my fuel levels and starting the car.
n0xlf
Castle Rock, CO
2003 Mustang Cobra
@solracarevir Looks like you are running UniFi. Since you are having OTA issues, it might be worth creating a separate "dumb" network and connect your Bronco to it in case there are connectivity issues that you aren't seeing.
They have made it pretty easy in recent controller releases to do this. Just create a separate 2.4GHz SSID and check this box:
Ford Bronco Sync update woes, OASIS / FDRS 1739373673079-b0
That will disable just about all network optimizations for that SSID. It also looks like you are using UniFi for routing. Be sure to exclude that network from any/all traffic filtering policies that you might be using.
This may not help anything, but worth a try in your case...
Go_UL_Cards
Wyatt
The Villages, FL
2024 4 Door Soft-top
@rugedraw - I looked at the cost for PTS - you are correct - not worth the price. I wish the list of updates would be available in ford pass. Microsoft windows will show you the list of updates it wants to install - seems like Ford should do the same. I can't find any history of what has been installed on Ford Pass. My bronco is connected to house wifi - one of the mesh routers is right there in the garage. Haven't ever seen any notification of any kind of update.
Ducati1098
Then you'd have people going into dealerships requesting updates constantly even when there isn't an issue. That's not something Ford or dealerships want.
Microsoft is a lot different when you can run the updates on your own.
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Again: Wifi is terribly overrated on the forums when it comes to OTA's and the OTA process in Ford vehicles. 99% of OTA's show this in the PTS OTA dashboard when an update gets pushed to a vehicle. Only two OTA's have ever shown a "yes" there. One was F150 specific and the other one was TCU update 23-PU113-UNX-DC and this was to address a config problem that broke connectivity in the modems rendering vehicles unable to talk to the mothership completely, so wifi was the only way to get the update sent to them.
Ford Bronco Sync update woes, OASIS / FDRS Untitled
Go_UL_Cards
Wyatt
The Villages, FL
I get that - but aren't these supposed to update over the air/wifi at home?
Greg2060
Greg
At the beach, NC
Chevy Silverado
Nope, they're still there. But what can't find is any info as to updates, like current version, when last was installed, etc. Under software updates it just shows that auto is on and the schedule.
Ford Bronco Sync update woes, OASIS / FDRS IMG_3918
